주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab A 7.0" Headphone Jack Replacement
필요한 것
  1. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement, Headphone Jack: 1 단계, 이미지 1/1
    • Using the plastic opening tool, starting at any corner on the tablet, insert the tool between the back panel and the front panel.
    • Slide tool around the tablet to unlock the panels from one another.
  2. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: 2 단계, 이미지 2/2
    • Carefully remove the back panel from the front panel.
    • The inner components of the tablet will now be exposed.
  3. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: 3 단계, 이미지 1/3 Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: 3 단계, 이미지 2/3 Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: 3 단계, 이미지 3/3
    • Remove the two Phillips head screws attaching the auxiliary port to the plastic frame using a P000 screwdriver.
    • Remove the four Phillips head screws attaching the motherboard to the plastic case using a P000 screwdriver.
  4. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Using tweezers disconnect the headphone jack connector from the motherboard.
  5. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: 5 단계, 이미지 1/3 Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: 5 단계, 이미지 2/3 Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: 5 단계, 이미지 3/3
    • Using tweezers, carefully lift up the motherboard.
    • Using tweezers, remove the metal jacket holding the headphone jack in place by grabbing the left corner where there is a recess to grab it.
    • There is a light adhesive holding the metal jacket down. You may have to pull slightly harder to get this off.
  6. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: 6 단계, 이미지 1/1
    • Remove the auxiliary port from the case.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Bradley Watson
회원 가입일: 02/15/17
1,079 평판
안내서 4개 작성하였습니다
USF Tampa, Team 5-4, Passmore Spring 2017 USF Tampa, Team 5-4, Passmore Spring 2017 회원
USFT-PASSMORE-S17S5G4
3 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 46
전체 시간: 4,029
