주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab A 9.7 Battery Replacement
필요한 것
  1. Samsung Galaxy Tab A 9.7  Battery Replacement, Back Cover: 1 단계, 이미지 1/1
    • Insert a metal spudger between the back case and the screen of the device.
    • The back cover is attached to the device by a series of snaps. The snaps are positioned about an inch from each other.
    • Move the spudger along the perimeter of the device while it is in between the back case and the screen to open each snap.
    • There will be an audible click every time a snap releases.
  2. Samsung Galaxy Tab A 9.7  Battery Replacement, Battery: 2 단계, 이미지 1/2 Samsung Galaxy Tab A 9.7  Battery Replacement, Battery: 2 단계, 이미지 2/2
    • Remove the eleven #000 Phillips 2.8mm screws that hold the battery in place.
  3. Samsung Galaxy Tab A 9.7  Battery Replacement: 3 단계, 이미지 1/2 Samsung Galaxy Tab A 9.7  Battery Replacement: 3 단계, 이미지 2/2
    • Place one hand on the battery and grasp the outer edge of the device with the other hand.
    • Flip the device over so that the battery falls over and onto your hand.
  4. Samsung Galaxy Tab A 9.7  Battery Replacement: 4 단계, 이미지 1/2 Samsung Galaxy Tab A 9.7  Battery Replacement: 4 단계, 이미지 2/2
    • Pull the battery out until it is only connected to the device by the black, yellow, and red connectors.
  5. Samsung Galaxy Tab A 9.7  Battery Replacement: 5 단계, 이미지 1/2 Samsung Galaxy Tab A 9.7  Battery Replacement: 5 단계, 이미지 2/2
    • Hold the battery and grip the wires with your thumb and finger.
    • Pull the wires away from the device to remove the white connector from the black socket.
    • Lift the battery away from the device.
결론
다른 13명이 해당 안내서를 완성하였습니다.
Paulina Nguyen
회원 가입일: 04/26/17
982 평판
안내서 6개 작성하였습니다
Cal Poly, Team S1-G3, Livingston Spring 2017 Cal Poly, Team S1-G3, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S1G3
1 회원
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 12
30일 전: 63
전체 시간: 11,255
