주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab A 9.7 Front Camera Replacement
필요한 것
  1. Samsung Galaxy Tab A 9.7 Front Camera Replacement, Front Camera: 1 단계, 이미지 1/1
    • Pry along the edge of the Samsung Galaxy Tab A 9.7 with an iFixit opening tool.
  2. Samsung Galaxy Tab A 9.7 Front Camera Replacement: 2 단계, 이미지 1/1
    • Insert a second iFixit opening tool along the edge and begin to pry open the back cover a little with each one.
  3. Samsung Galaxy Tab A 9.7 Front Camera Replacement: 3 단계, 이미지 1/1
    • Remove one of the opening tools and begin to go around the device with the other one until the back cover pops off.
  4. Samsung Galaxy Tab A 9.7 Front Camera Replacement: 4 단계, 이미지 1/1
    • Locate the camera at the top of the device.
  5. Samsung Galaxy Tab A 9.7 Front Camera Replacement: 5 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Pull up carefully on the orange strip using the tweezers.
    • The lever holding the strip in place will pop up, releasing the camera.
  6. Samsung Galaxy Tab A 9.7 Front Camera Replacement: 6 단계, 이미지 1/1
    • Remove the front camera and replace it with the new part.
결론
Makenzie D'Elia
회원 가입일: 04/09/19
313 평판
안내서 2개 작성하였습니다
IUPUI, Team S1-G3, Hovde Spring 2019 IUPUI, Team S1-G3, Hovde Spring 2019 회원
IUPUI-HOVDE-S19S1G3
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 270
