소개
If your device is unable to store information, you may be in need of a new or upgraded SD card. This guide will outline how to properly remove the SD card without damaging other parts of the device. The difficulty of this guide is very easy and it will not require any prior experience.
There is no SD card in the pictures but the area where the card is stored is clearly identified.
필요한 것
Using a plastic spudger or finger nail, Open the port labeled micro SD using a plastic spudger or finger nail.
다른 한 분이 해당 안내서를 완성하였습니다.
