주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab A 9.7 Speakers Replacement
필요한 것
  1. Samsung Galaxy Tab A 9.7 Speakers Replacement, Back Cover: 1 단계, 이미지 1/1
    • Insert a metal spudger between the back case and the screen of the device.
    • The back cover is attached to the device by a series of snaps. The snaps are positioned about an inch from each other.
    • Move the spudger along the perimeter of the device while it is in between the back case and the screen to open each snap.
    • There will be an audible click every time a snap releases.
  2. Samsung Galaxy Tab A 9.7 Speakers Replacement, Speakers: 2 단계, 이미지 1/2 Samsung Galaxy Tab A 9.7 Speakers Replacement, Speakers: 2 단계, 이미지 2/2
    • Remove the two 2.8 mm Phillips #000 screws from the speakers.
  3. Samsung Galaxy Tab A 9.7 Speakers Replacement: 3 단계, 이미지 1/1
    • Each speaker is now only connected to the main device by small plastic snaps.
    • Pry the speakers from the device at these two points using the heavy duty spudger.
결론
Paulina Nguyen
회원 가입일: 04/26/17
982 평판
안내서 6개 작성하였습니다
Cal Poly, Team S1-G3, Livingston Spring 2017 Cal Poly, Team S1-G3, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S1G3
1 회원
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 9
전체 시간: 1,468
