주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy Tab A Battery Replacement
필요한 것
  1. Samsung Galaxy Tab A Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Make sure the device is turned off before attempting to disassemble it.
    • At the top portion of the memory card slot, use the small metal spudger to create separation between the back cover and the rest of the device.
    • The small metal spudger is only used to create separation between the back cover and the rest of the device, not to remove the back cover.
    • If possible, try to use a normal nylon spudger to separate the back cover, as it is much softer and less likely to mar/scratch the device.
  2. Samsung Galaxy Tab A Battery Replacement: 2 단계, 이미지 2개 중 1개 Samsung Galaxy Tab A Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Use the intermediate metal spudger in place of the small metal spudger to remove the back cover. This is done by sliding the intermediate metal spudger around the perimeter of the device, beginning at the top portion of the memory card slot.
    • The second picture shows the internal portion of the device once the back cover is removed.
  3. Samsung Galaxy Tab A Battery Replacement: 3 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    $3.99
    • Disconnect the electrical connector from the motherboard using the bent precision tweezers.
    • Avoid touching the motherboard with the tweezers. Metal tools such as the tweezers can scratch the motherboard and potentially cause damage.
  4. Samsung Galaxy Tab A Battery Replacement: 4 단계, 이미지 3개 중 1개 Samsung Galaxy Tab A Battery Replacement: 4 단계, 이미지 3개 중 2개 Samsung Galaxy Tab A Battery Replacement: 4 단계, 이미지 3개 중 3개
    • Use the flat end of the plastic spudger to pry the battery apart from the rest of the device.
    • An alternative method is to loosen the battery using the plastic spudger, and then to remove the battery by pulling on the paper tab that says "Pull (Hands Only)."
    • Once the back cover and battery are removed, the device should look like as illustrated in the second picture.
결론
다른 90명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Michael Wozny
회원 가입일: 02/04/16
3,794 평판
안내서 5개를 작성함
USF Tampa, Team 17-4, Blackwell Winter 2016 USF Tampa, Team 17-4, Blackwell Winter 2016 회원
USFT-BLACKWELL-W16S17G4
4 회원들
안내서 12개를 작성함
31가이드 댓글
Thank you so much !
Mindy A Gjestrum - 답글 공유
please help us
The Tab A of my son we dont know what happen they shut down we can not open it.
but the charger is ok but we try to chargers the device is not open it.
The Tab A is 7 mounths using only thats why we are worried what happen.
Please help thanks,
Rashier Yahiya - 답글 공유
My 10.1" died suddenly - never dropped, shocked - worked fine in the morning, wouldn't come on two hours later. Won't take a charge or show ANY sign of life. 53 weeks old and maybe 10 hour use a week. I can't seem to open it without making a mess out of it. I was impressed by the product when it was working - certainly NOT impressed anymore. A very shiny and expensive paperweight.
Muddy - 답글 공유
Long time since you posted this, but clean out the micro USB charge port. Use a toothpick gently, and vacuum. A lot of lint and dirt gets in and stops a proper connection
Darla Lamb - 답글 공유
i looked everywhere online for a simple guide with pics for tab a and all i found was tab 2 and up so THANK YOU SO MUCH !!!!!!
cc rancour - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 14
지난 7일: 145
지난 30일: 671
전체 시간: 368,607
