소개
Over time, an earphone jack can become worn down to the point that it no longer connects properly to a wired headset. This guide highlights how to remove the back cover of the tablet in order to get to the earphone jack as a means to replace it.
필요한 것
At the top portion of the memory card slot, use the small metal spudger to create separation between the back cover and the rest of the device.
Use the intermediate metal spudger in place of the small metal spudger to remove the back cover. This is done by sliding the intermediate metal spudger around the perimeter of the device, beginning at the top portion of the memory card slot.
The second picture shows the internal portion of the device once the back cover is removed.
다른 3명이 해당 안내서를 완성하였습니다.
