주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab A Rear Facing Camera Replacement
필요한 것
  1. Samsung Galaxy Tab A Rear Facing Camera Replacement, Rear Facing Camera: 1 단계, 이미지 1/1
    • Make sure the device is turned off before attempting to disassemble it.
    • At the top portion of the memory card slot, use the small metal spudger to create separation between the back cover and the rest of the device.
    • The small metal spudger is only used to create separation between the back cover and the rest of the device, not to remove the back cover.
  2. Samsung Galaxy Tab A Rear Facing Camera Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Tab A Rear Facing Camera Replacement: 2 단계, 이미지 2/2
    • Use the intermediate metal spudger in place of the small metal spudger to remove the back cover. This is done by sliding the intermediate metal spudger around the perimeter of the device, beginning at the top portion of the memory card slot.
    • The second picture shows the internal portion of the device once the back cover is removed.
  3. Samsung Galaxy Tab A Rear Facing Camera Replacement: 3 단계, 이미지 1/2 Samsung Galaxy Tab A Rear Facing Camera Replacement: 3 단계, 이미지 2/2
    • Use the spudger to disconnect the camera from the motherboard.
    • This step should be done at the yellow rubber portion of the camera.
    • The first and second pictures show what the camera looks like when it is still connected to the motherboard and once it is disconnected, respectively.
  4. Samsung Galaxy Tab A Rear Facing Camera Replacement: 4 단계, 이미지 1/1
    • Use the spudger to remove the main body of the camera from the rest of the device. This should be done anywhere around the black-framed perimeter of the camera.
  5. Samsung Galaxy Tab A Rear Facing Camera Replacement: 5 단계, 이미지 1/3 Samsung Galaxy Tab A Rear Facing Camera Replacement: 5 단계, 이미지 2/3 Samsung Galaxy Tab A Rear Facing Camera Replacement: 5 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use the tweezers to fully remove the camera from the rest of the device. The camera should be pulled out and away from where the device was connected to the motherboard in Step 3.
    • The second picture illustrates what the device should look like once the camera is removed.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Michael Wozny
회원 가입일: 02/04/16
3,693 평판
안내서 5개 작성하였습니다
USF Tampa, Team 17-4, Blackwell Winter 2016 USF Tampa, Team 17-4, Blackwell Winter 2016 회원
USFT-BLACKWELL-W16S17G4
4 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 17
전체 시간: 2,282
