소개
The rear camera of the Samsung Galaxy Tab E 8.0 can be damaged if the camera is struck by a hard object. This guide shows how to replace the tablet's rear camera, which is attached to the motherboard.
필요한 것
Use the iFixit Opening Tool to pry off the back case, moving the tool around the screen.
이 단계에 사용된 도구:Tweezers$4.99
Use the tweezers to lift the switch connecting the back camera to the motherboard.
Use your hand to remove the back camera from the motherboard.
다른 4명이 해당 안내서를 완성하였습니다.
