주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab E 8.0 Screen Replacement
필요한 것
  1. Samsung Galaxy Tab E 8.0 Screen Replacement, Back Panel: 1 단계, 이미지 1/2 Samsung Galaxy Tab E 8.0 Screen Replacement, Back Panel: 1 단계, 이미지 2/2
    • Use the iFixit Opening Tool to pry off the back case, moving the tool around the screen.
    • Make sure the device is off and the SD card is removed before taking off the back casing.
  2. Samsung Galaxy Tab E 8.0 Screen Replacement, Back Camera: 2 단계, 이미지 1/2 Samsung Galaxy Tab E 8.0 Screen Replacement, Back Camera: 2 단계, 이미지 2/2
    • Use the tweezers to lift the switch connecting the back camera to the motherboard.
    • Use your hand to remove the back camera from the motherboard.
  3. Samsung Galaxy Tab E 8.0 Screen Replacement, Front Camera: 3 단계, 이미지 1/3 Samsung Galaxy Tab E 8.0 Screen Replacement, Front Camera: 3 단계, 이미지 2/3 Samsung Galaxy Tab E 8.0 Screen Replacement, Front Camera: 3 단계, 이미지 3/3
    • Use the tweezers to lift the switch connecting the front camera to the motherboard.
    • Remove the front camera from the motherboard by lifting with the tweezers.
  4. Samsung Galaxy Tab E 8.0 Screen Replacement, Motherboard: 4 단계, 이미지 1/2 Samsung Galaxy Tab E 8.0 Screen Replacement, Motherboard: 4 단계, 이미지 2/2
    • Use the tweezers to flip the switch on the bottom of the strap that goes over the battery.
    • Release the strap from the switch by lifting the strap with your hand.
  5. Samsung Galaxy Tab E 8.0 Screen Replacement: 5 단계, 이미지 1/2 Samsung Galaxy Tab E 8.0 Screen Replacement: 5 단계, 이미지 2/2
    • Use the tweezers to flip the switch that connects the top of the strap to the motherboard.
    • Lift the top end of the strap with your hand and remove the strap completely from the device.
  6. Samsung Galaxy Tab E 8.0 Screen Replacement: 6 단계, 이미지 1/2 Samsung Galaxy Tab E 8.0 Screen Replacement: 6 단계, 이미지 2/2
    • Use the tweezers to flip the switch of the connector.
    • Lift the connector from the motherboard.
    • This connector does not come completely off, but disconnects from the motherboard.
  7. Samsung Galaxy Tab E 8.0 Screen Replacement: 7 단계, 이미지 1/2 Samsung Galaxy Tab E 8.0 Screen Replacement: 7 단계, 이미지 2/2
    • Use the tweezers to flip the switch of the blue connector on the motherboard.
    • This switch can detach from the device, but just needs to disconnect from the motherboard.
    • Ensure the blue ribbon cable is not under the motherboard upon reassembly.
  8. Samsung Galaxy Tab E 8.0 Screen Replacement: 8 단계, 이미지 1/2 Samsung Galaxy Tab E 8.0 Screen Replacement: 8 단계, 이미지 2/2
    • Use the tweezers to flip the switch of the connector that runs from the battery to the motherboard.
  9. Samsung Galaxy Tab E 8.0 Screen Replacement: 9 단계, 이미지 1/2 Samsung Galaxy Tab E 8.0 Screen Replacement: 9 단계, 이미지 2/2
    • Use a JIS #00 screwdriver to remove the six 4.5mm screws at the top of the motherboard.
    • Lift the motherboard with your hand to detach the motherboard from the device.
  10. Samsung Galaxy Tab E 8.0 Screen Replacement, Battery: 10 단계, 이미지 1/3 Samsung Galaxy Tab E 8.0 Screen Replacement, Battery: 10 단계, 이미지 2/3 Samsung Galaxy Tab E 8.0 Screen Replacement, Battery: 10 단계, 이미지 3/3
    • Use the tweezers to lift the flap on the left end of the battery and pull up with your hand to remove the battery.
    • The battery is held by an adhesive on the back, so it will take some force to remove.
  11. Samsung Galaxy Tab E 8.0 Screen Replacement, Screen: 11 단계, 이미지 1/2 Samsung Galaxy Tab E 8.0 Screen Replacement, Screen: 11 단계, 이미지 2/2
    • Use an iOpener or a heat gun/hair dryer to warm the outer 1/2 inch of the screen. It should be very warm but not too hot to touch or you may cause heat damage to components inside the device.
    • Use the iFixit Opening Tool to get between the plastic screen and the device to pry off the screen.
    • The metal spudger may be needed to get between the screen.
    • The metal spudger may cause more damage to the screen if used with force.
  12. Samsung Galaxy Tab E 8.0 Screen Replacement: 12 단계, 이미지 1/2 Samsung Galaxy Tab E 8.0 Screen Replacement: 12 단계, 이미지 2/2
    • Use the metal spudger to get between the device and the internal screen.
    • Pry out the screen from the device.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Christian Bloemhof
회원 가입일: 10/08/18
1,102 평판
안내서 7개 작성하였습니다
Cal Poly, Team S13-G4, White Fall 2018 Cal Poly, Team S13-G4, White Fall 2018 회원
CPSU-WHITE-F18S13G4
4 회원들
안내서 8개 작성하였습니다
댓글 한 개
I am working on a 7” lite E. Is the procedure about the same?
George Tedrick - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 9
30일 전: 43
전체 시간: 8,945
