주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement
필요한 것
  1. Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement, Back Camera: 1 단계, 이미지 1/1
    • Make sure the device is turned off.
    • Using the plastic opening tool, start in the center and wedge the angled tip between the plastic back and the scree.
    • Try to pressure it, wedge it back and forth.
    • Do not wedge the plastic opening tool directly on top of the power buttons and headphone buttons.
  2. Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: 2 단계, 이미지 2/2
    • Once the bottom edge has been loosened, use the suction tool to pull it.
    • The second picture shows the internal portion of the tablet once the back cover is removed.
  3. Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: 3 단계, 이미지 1/2 Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: 3 단계, 이미지 2/2
    • The first picture shows the location of back camera.
    • Disconnect the rectangular connection from the back camera to the motherboard.
  4. Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: 4 단계, 이미지 1/2 Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: 4 단계, 이미지 2/2
    • The picture illustrates what the device should look like once the back camera is removed.
결론
Tingting Liu
회원 가입일: 09/28/16
25 평판
안내서 1개 작성함
USF Tampa, Team 1-4, Cagle Fall 2016 USF Tampa, Team 1-4, Cagle Fall 2016 회원
USFT-CAGLE-F16S1G4
3 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 1,240
