주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab E 9.6 Verizon Back Casing Replacement
필요한 것
  1. Samsung Galaxy Tab E 9.6 Verizon Back Casing Replacement, Back Casing: 1 단계, 이미지 1/1
    • Remove any micro-SD or SIM cards before continuing.
    • Verify your device is turned OFF.
    • Disconnect all external devices from your tablet.
  2. Samsung Galaxy Tab E 9.6 Verizon Back Casing Replacement: 2 단계, 이미지 1/3 Samsung Galaxy Tab E 9.6 Verizon Back Casing Replacement: 2 단계, 이미지 2/3 Samsung Galaxy Tab E 9.6 Verizon Back Casing Replacement: 2 단계, 이미지 3/3
    • Insert the plastic opening tool by wedging it between the device's screen and back cover.
    • Move the plastic tool around the edges of the device to undo the plastic lips holding the casing together.
    • This step may require more force than expected. If difficult, try using a suction cup on the screen.
  3. Samsung Galaxy Tab E 9.6 Verizon Back Casing Replacement: 3 단계, 이미지 1/3 Samsung Galaxy Tab E 9.6 Verizon Back Casing Replacement: 3 단계, 이미지 2/3 Samsung Galaxy Tab E 9.6 Verizon Back Casing Replacement: 3 단계, 이미지 3/3
    • This process will become easier as more clips are separated.
    • Use your hands to gently pull the back cover off the device after about half of the clips are separated.
    • A suction cup can be used in this step as well to assist in pulling the device apart.
결론
Dave Dorzback
회원 가입일: 09/28/16
626 평판
안내서 4개 작성하였습니다
USF Tampa, Team 1-4, Cagle Fall 2016 USF Tampa, Team 1-4, Cagle Fall 2016 회원
USFT-CAGLE-F16S1G4
3 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 5
30일 전: 17
전체 시간: 2,673
