소개
Front panel removal for the Samsung Galaxy Tab E Verizon.
필요한 것
Turn the device back over and use a plastic opening tool to detach the adhesive glue securing the front casing.
You will need to wedge a plastic opening tool in between the front casing and the screen. Then move the tool around the perimeter of the device to break the adhesive.
Once you've loosed the front panel enough with the prying tool, you can use your hands to pull the front panel off of the device.
다른 6명이 해당 안내서를 완성하였습니다.
