주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab E Lite 7 Kids Battery Replacement
필요한 것
  1. Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Rear Case: 1 단계, 이미지 1/3 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Rear Case: 1 단계, 이미지 2/3 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Rear Case: 1 단계, 이미지 3/3
    • Make sure the device is turned off before attempting to disassemble it.
    • Using a plastic opening tool, wedge in the seam between the screen and the case.
    • Rock the tool by moving it towards and away from the middle of the screen, trying to separate the tape holding the screen and case together.
  2. Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: 2 단계, 이미지 2/2
    • After separating the latches holding the screen and case together, slowly take the screen off the case.
  3. Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Battery: 3 단계, 이미지 1/3 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Battery: 3 단계, 이미지 2/3 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Battery: 3 단계, 이미지 3/3
    • Use the plastic opening tool to gently lift the black ZIF (zero insertion force) connector shown within the red circle.
    • Use your hands to pull the black cable out of its slot.
  4. Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: 4 단계, 이미지 1/2 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: 4 단계, 이미지 2/2
    • Use the plastic opening tool to gently lift black ZIF (zero insertion force) connector shown within the red square.
    • Now gently pull out the battery's ribbon cable.
  5. Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: 5 단계, 이미지 1/3 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: 5 단계, 이미지 2/3 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: 5 단계, 이미지 3/3
    • Use the plastic opening tool and gently pry out the battery from the left-hand side.
    • Grab the battery and lift it up.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Nicholas Nolan
회원 가입일: 02/17/17
805 평판
안내서 5개 작성하였습니다
USF Tampa, Team S19-G2, Hoffman Spring 2017 USF Tampa, Team S19-G2, Hoffman Spring 2017 회원
USFT-HOFFMAN-S17S19G2
4 회원들
안내서 7개 작성하였습니다
댓글 한 개
Great information.  You need to show how to replace a screen- LCD for a Samsung Galaxy TAB E Lite Kids.
Paul McWilliams - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 4
30일 전: 13
전체 시간: 3,002
