소개
This replacement guide will show you how to replace the battery in your Samsung Galaxy Tab E Lite 7 Kids. You will need to follow the instructions carefully as to not damage any fragile components in your tablet.
필요한 것
Using a plastic opening tool, wedge in the seam between the screen and the case.
Rock the tool by moving it towards and away from the middle of the screen, trying to separate the tape holding the screen and case together.
Use the plastic opening tool to gently lift the black ZIF (zero insertion force) connector shown within the red circle.
Use your hands to pull the black cable out of its slot.
다른 5명이 해당 안내서를 완성하였습니다.
댓글 한 개
Great information. You need to show how to replace a screen- LCD for a Samsung Galaxy TAB E Lite Kids.
