주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab E Lite 7 Kids Camera Replacement
필요한 것
  1. Samsung Galaxy Tab E Lite 7 Kids Camera Replacement, Rear Case: 1 단계, 이미지 1/3 Samsung Galaxy Tab E Lite 7 Kids Camera Replacement, Rear Case: 1 단계, 이미지 2/3 Samsung Galaxy Tab E Lite 7 Kids Camera Replacement, Rear Case: 1 단계, 이미지 3/3
    • Make sure the device is turned off before attempting to disassemble it.
    • Using a plastic opening tool, wedge in the seam between the screen and the case.
    • Rock the tool by moving it towards and away from the middle of the screen, trying to separate the tape holding the screen and case together.
  2. Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: 2 단계, 이미지 2/2
    • After separating the latches holding the screen and case together, slowly take the screen off the case.
  3. Samsung Galaxy Tab E Lite 7 Kids Camera Replacement, Motherboard: 3 단계, 이미지 1/3 Samsung Galaxy Tab E Lite 7 Kids Camera Replacement, Motherboard: 3 단계, 이미지 2/3 Samsung Galaxy Tab E Lite 7 Kids Camera Replacement, Motherboard: 3 단계, 이미지 3/3
    • Use the plastic opening tool to lift up the black ZIF (zero insertion force) connector.
    • Use your hands to pull the black cable out of its slot.
  4. Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: 4 단계, 이미지 1/2 Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: 4 단계, 이미지 2/2
    • Use the plastic opening tool to lift the ZIF (zero insertion force) connector holding the ribbon cable.
    • Pull out the battery's ribbon cable.
  5. Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: 5 단계, 이미지 1/2 Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: 5 단계, 이미지 2/2
    • Use the plastic opening tool to lift up the latch to the ribbon cable.
    • Remove the ribbon cable from the connector.
  6. Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: 6 단계, 이미지 1/1
    • Remove the seven 4mm PH000 screws holding the motherboard in place.
  7. Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: 7 단계, 이미지 1/1
    • Use the plastic opening tool to pry up the tab holding the motherboard in place.
  8. Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: 8 단계, 이미지 1/3 Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: 8 단계, 이미지 2/3 Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: 8 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use the precision tweezers to remove the black plastic corner on top of the motherboard.
    • Use the plastic opening tool to pull the motherboard out of the case.
  9. Samsung Galaxy Tab E Lite 7 Kids Camera Replacement, Camera: 9 단계, 이미지 1/2 Samsung Galaxy Tab E Lite 7 Kids Camera Replacement, Camera: 9 단계, 이미지 2/2
    • Flip the motherboard over.
    • Use a plastic opening tool to lift up the latch holding the camera cable.
  10. Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: 10 단계, 이미지 1/3 Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: 10 단계, 이미지 2/3 Samsung Galaxy Tab E Lite 7 Kids Camera Replacement: 10 단계, 이미지 3/3
    • Pull the ribbon cable and the camera.
결론
Jordan Bermudez
회원 가입일: 02/17/17
285 평판
안내서 2개 작성하였습니다
USF Tampa, Team S19-G2, Hoffman Spring 2017 USF Tampa, Team S19-G2, Hoffman Spring 2017 회원
USFT-HOFFMAN-S17S19G2
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 323
