소개
Diese Anleitung zeigt dir, wie du den Akku beim Samsung Galaxy Tab Pro 10.1 austauschst. Zuerst wird die Rückseite vom Gerät entfernt, um an die Innenseite zu gelangen, wo der Akku verbaut ist. Dann kommen die Schritte, um den Akku zu entfernen.
필요한 것
Stecke ein Öffnungswerkzeug aus Plastik in den Spalt zwischen dem Display und der Umrandung.
Gehe den ganzen Spalt mit dem Öffnungswerkzeug entlang.
Lege die Rückblende neben das restliche Gehäuse.
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
다른 21명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 8개
My Samsung Galaxy Tab Pro sm-t520 screen pooped up from the base where the plugin for charging, only partly, and the screen is pretty much bowed up what can I do and the home button is very loose just happened by itself heard a pop like plastic sound and then looked and now Where home button is screen bowed up slightly how can that happen, I use the charger etc that came with my tablet and what would it cost to fix around figure possibly can a battery go bad even when I have not charged it in a long time, have not even been playing on it for several weeks. Please help ty
Oh it was a loud snap sound.
Well can't open it cause have not the right tools.
I would invest in a Opening Tools
like the one from ifixit so you can open the tablet. You need to see how it looks inside to know if you can repair and how.
Claes -
