주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab Pro 10.1 Front Facing Camera Replacement
필요한 것
  1. Samsung Galaxy Tab Pro 10.1 Front Facing Camera Replacement, Rear Panel: 1 단계, 이미지 1/2 Samsung Galaxy Tab Pro 10.1 Front Facing Camera Replacement, Rear Panel: 1 단계, 이미지 2/2
    • Be gentle, the front panel is connected to sensitive wiring that may snap if too much pressure is applied.
    • Insert a plastic opening tool into the crevice between the screen and the side of the tablet.
    • Go around the entire crevice with the plastic opening tool.
    • Set aside the separated front and rear panels of the device.
  2. Samsung Galaxy Tab Pro 10.1 Front Facing Camera Replacement, Front Facing Camera: 2 단계, 이미지 1/3 Samsung Galaxy Tab Pro 10.1 Front Facing Camera Replacement, Front Facing Camera: 2 단계, 이미지 2/3 Samsung Galaxy Tab Pro 10.1 Front Facing Camera Replacement, Front Facing Camera: 2 단계, 이미지 3/3
    • Use plastic tweezers to carefully detach the front-facing camera from the motherboard.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Stephen Yeung
회원 가입일: 08/26/15
1,514 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 1,029
