주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab Pro 10.1 Motherboard Replacement
필요한 것
  1. Samsung Galaxy Tab Pro 10.1 Motherboard Replacement, Rear Panel: 1 단계, 이미지 1/2 Samsung Galaxy Tab Pro 10.1 Motherboard Replacement, Rear Panel: 1 단계, 이미지 2/2
    • Be gentle, the front panel is connected to sensitive wiring that may snap if too much pressure is applied.
    • Insert a plastic opening tool into the crevice between the screen and the side of the tablet.
    • Go around the entire crevice with the plastic opening tool.
    • Set aside the separated front and rear panels of the device.
  2. Samsung Galaxy Tab Pro 10.1 Motherboard Replacement, Battery Cables: 2 단계, 이미지 1/2 Samsung Galaxy Tab Pro 10.1 Motherboard Replacement, Battery Cables: 2 단계, 이미지 2/2
    • Remove the six 4 mm Phillips #00 screws that hold the battery in place.
  3. Samsung Galaxy Tab Pro 10.1 Motherboard Replacement: 3 단계, 이미지 1/3 Samsung Galaxy Tab Pro 10.1 Motherboard Replacement: 3 단계, 이미지 2/3 Samsung Galaxy Tab Pro 10.1 Motherboard Replacement: 3 단계, 이미지 3/3
    • Remove the tape that runs along the length of the battery.
    • Lift the retaining flaps of the ZIF connectors on each side of the battery connector.
    • Remove the two ribbon cables that lay across the width of the battery and are connected to the motherboard. Place your finger underneath the ribbon cable and gently lift the cable upwards and off.
  4. Samsung Galaxy Tab Pro 10.1 Motherboard Replacement: 4 단계, 이미지 1/2 Samsung Galaxy Tab Pro 10.1 Motherboard Replacement: 4 단계, 이미지 2/2
    • Use a plastic tweezer and remove the top center 6 pin power connector that is attached to the edge of the motherboard.
    • Detach the battery by gently lifting the battery out of the panel.
  5. Samsung Galaxy Tab Pro 10.1 Motherboard Replacement, Front Facing Camera: 5 단계, 이미지 1/3 Samsung Galaxy Tab Pro 10.1 Motherboard Replacement, Front Facing Camera: 5 단계, 이미지 2/3 Samsung Galaxy Tab Pro 10.1 Motherboard Replacement, Front Facing Camera: 5 단계, 이미지 3/3
    • Use plastic tweezers to carefully detach the front-facing camera from the motherboard.
  6. Samsung Galaxy Tab Pro 10.1 Motherboard Replacement, Rear Facing Camera: 6 단계, 이미지 1/3 Samsung Galaxy Tab Pro 10.1 Motherboard Replacement, Rear Facing Camera: 6 단계, 이미지 2/3 Samsung Galaxy Tab Pro 10.1 Motherboard Replacement, Rear Facing Camera: 6 단계, 이미지 3/3
    • Use plastic tweezers and carefully detach the rear-facing camera from the motherboard.
  7. Samsung Galaxy Tab Pro 10.1 Motherboard Replacement, Motherboard: 7 단계, 이미지 1/2 Samsung Galaxy Tab Pro 10.1 Motherboard Replacement, Motherboard: 7 단계, 이미지 2/2
    • Remove the five ribbon cables holding the motherboard together with a plastic tweezer.
  8. Samsung Galaxy Tab Pro 10.1 Motherboard Replacement: 8 단계, 이미지 1/2 Samsung Galaxy Tab Pro 10.1 Motherboard Replacement: 8 단계, 이미지 2/2
    • Remove the Phillips #00 screws from the plastic part holding down the motherboard.
  9. Samsung Galaxy Tab Pro 10.1 Motherboard Replacement: 9 단계, 이미지 1/1
    • Gently lift the motherboard from the front panel enclosure.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Stephen Yeung
회원 가입일: 08/26/15
1,526 평판
안내서 6개 작성하였습니다
댓글 3개
very useful,thanks a lot.
Singh
bandna kaur matta - 답글
ارغب باصلاح شريحة الاتصال
mazinmandour - 답글
Thanks for this manual. Can you help me recognise the Wifi/BT module? I have a problem with that - with some luck it is just the connector....
Arno - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 4
전체 시간: 6,370
