소개
This guide will show how to replace or remove the rear panel on the Samsung Galaxy Tab Pro 10.1. The rear panel can be removed to either access the interior of the device or removed for replacement. The guide will outline how to remove the rear panel from the front panel enclosure.
필요한 것
Insert a plastic opening tool into the crevice between the screen and the side of the tablet.
Go around the entire crevice with the plastic opening tool.
Set aside the separated front and rear panels of the device.
다른 10명이 해당 안내서를 완성하였습니다.
