주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab Pro 8.4 Back Camera Replacement
필요한 것
  1. Samsung Galaxy Tab Pro 8.4 Back Camera Replacement, Battery: 1 단계, 이미지 1/1
    • Begin by separating the back panel from the screen glass assembly using the plastic opening tool.
    • Insert the plastic opening tool between the edge of the glass screen and the metal frame around the device.
  2. Samsung Galaxy Tab Pro 8.4 Back Camera Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Tab Pro 8.4 Back Camera Replacement: 2 단계, 이미지 2/2
    • Continue around the entire device until the back panel is completely separated from the screen.
  3. Samsung Galaxy Tab Pro 8.4 Back Camera Replacement: 3 단계, 이미지 1/2 Samsung Galaxy Tab Pro 8.4 Back Camera Replacement: 3 단계, 이미지 2/2
    • Remove the four 2.5mm Phillips #000 screws.
  4. Samsung Galaxy Tab Pro 8.4 Back Camera Replacement: 4 단계, 이미지 1/1
    • Gently pull up on the plastic tab that has red, blue and black wires that connects the battery to the motherboard.
  5. Samsung Galaxy Tab Pro 8.4 Back Camera Replacement: 5 단계, 이미지 1/1
    • The battery should be completely disconnected and the new one can be installed.
  6. Samsung Galaxy Tab Pro 8.4 Back Camera Replacement, Motherboard: 6 단계, 이미지 1/3 Samsung Galaxy Tab Pro 8.4 Back Camera Replacement, Motherboard: 6 단계, 이미지 2/3 Samsung Galaxy Tab Pro 8.4 Back Camera Replacement, Motherboard: 6 단계, 이미지 3/3
    • Remove all the clips that are attached to the motherboard using your fingers or a nylon spudger.
  7. Samsung Galaxy Tab Pro 8.4 Back Camera Replacement: 7 단계, 이미지 1/3 Samsung Galaxy Tab Pro 8.4 Back Camera Replacement: 7 단계, 이미지 2/3 Samsung Galaxy Tab Pro 8.4 Back Camera Replacement: 7 단계, 이미지 3/3
    • There are four Phillips head screws (2.5mm) that need to be removed:
    • Two on the charging port, which is the small metallic piece at the bottom of the device.
    • There is one screw that is covered by a small green tape. The tape must be peeled off before the screw under can be removed.
    • The last screw is found on a speaker at the bottom right of the device. Once the screw is removed, the speaker must be removed as well.
  8. Samsung Galaxy Tab Pro 8.4 Back Camera Replacement: 8 단계, 이미지 1/3 Samsung Galaxy Tab Pro 8.4 Back Camera Replacement: 8 단계, 이미지 2/3 Samsung Galaxy Tab Pro 8.4 Back Camera Replacement: 8 단계, 이미지 3/3
    • There is a small wire that connects the motherboard to the bottom right corner.
    • Gently pull the end of the wire that attaches the motherboard to the device until the wire is disconnected.
    • After the cord is disconnected, the motherboard can be removed from the tablet by simply lifting it from the device.
  9. Samsung Galaxy Tab Pro 8.4 Back Camera Replacement, Back Camera: 9 단계, 이미지 1/2 Samsung Galaxy Tab Pro 8.4 Back Camera Replacement, Back Camera: 9 단계, 이미지 2/2
    • Once the motherboard has been removed, use a plastic opening tool to gently push the camera out of its place.
  10. Samsung Galaxy Tab Pro 8.4 Back Camera Replacement: 10 단계, 이미지 1/2 Samsung Galaxy Tab Pro 8.4 Back Camera Replacement: 10 단계, 이미지 2/2
    • Using your fingers, gently pull the camera out of its place.
결론
Mario Montoya
회원 가입일: 09/12/16
225 평판
안내서 2개 작성하였습니다
USF Tampa, Team 9-2, Lacy Fall 2016 USF Tampa, Team 9-2, Lacy Fall 2016 회원
USFT-LACY-F16S9G2
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 16
전체 시간: 661
