주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab Pro 8.4 Battery Replacement
필요한 것
  1. Samsung Galaxy Tab Pro 8.4 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Begin by separating the back panel from the screen glass assembly using the plastic opening tool.
    • Insert the plastic opening tool between the edge of the glass screen and the metal frame around the device.
  2. Samsung Galaxy Tab Pro 8.4 Battery Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Tab Pro 8.4 Battery Replacement: 2 단계, 이미지 2/2
    • Continue around the entire device until the back panel is completely separated from the screen.
  3. Samsung Galaxy Tab Pro 8.4 Battery Replacement: 3 단계, 이미지 1/2 Samsung Galaxy Tab Pro 8.4 Battery Replacement: 3 단계, 이미지 2/2
    • Remove the four 2.5mm Phillips #000 screws.
  4. Samsung Galaxy Tab Pro 8.4 Battery Replacement: 4 단계, 이미지 1/1
    • Gently pull up on the plastic tab that has red, blue and black wires that connects the battery to the motherboard.
  5. Samsung Galaxy Tab Pro 8.4 Battery Replacement: 5 단계, 이미지 1/1
    • The battery should be completely disconnected and the new one can be installed.
결론
다른 21명이 해당 안내서를 완성하였습니다.
Jonathan Romine
회원 가입일: 09/12/16
1,072 평판
안내서 2개 작성하였습니다
USF Tampa, Team 9-2, Lacy Fall 2016 USF Tampa, Team 9-2, Lacy Fall 2016 회원
USFT-LACY-F16S9G2
4 회원들
안내서 10개 작성하였습니다
댓글 한 개
Samsung Galaxy tab ki battery 4800 mah
Razwan good ashqui - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 23
전체 시간: 12,082
