주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab Pro 8.4 Charging Port Replacement
필요한 것
  1. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement, Battery: 1 단계, 이미지 1/1
    • Begin by separating the back panel from the screen glass assembly using the plastic opening tool.
    • Insert the plastic opening tool between the edge of the glass screen and the metal frame around the device.
  2. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: 2 단계, 이미지 2/2
    • Continue around the entire device until the back panel is completely separated from the screen.
  3. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: 3 단계, 이미지 1/2 Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: 3 단계, 이미지 2/2
    • Remove the four 2.5mm Phillips #000 screws.
  4. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: 4 단계, 이미지 1/1
    • Gently pull up on the plastic tab that has red, blue and black wires that connects the battery to the motherboard.
  5. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: 5 단계, 이미지 1/1
    • The battery should be completely disconnected and the new one can be installed.
    Just two things I’d like to add. In step 2, one can see where the bottom clips to the top with the mainboard, and it’s easier if one pries adjacent to those clips. Secondly, one shouldn’t tighten the screws for the battery too much, I tightened them till they were tight but ended up having to take it apart again and loosen them by around a turn or so. If they are too tight, they will warp the diffuser/reflector/light guide for the LCD panel and there’ll be brighter spots in the LCD screen. The screws originally have thread lock, so I guess if one isn’t confident the screws will stay in place it’s best to re-apply some, though as they are screwing into a plastic frame, the hope is that the plastic provides enough friction for the screw to remain in place.
    Christopher Chan - 답글
  6. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement, Charging Port: 6 단계, 이미지 1/2 Samsung Galaxy Tab Pro 8.4 Charging Port Replacement, Charging Port: 6 단계, 이미지 2/2
    • Remove the two 2.5mm Phillips #000 screws.
  7. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: 7 단계, 이미지 1/3 Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: 7 단계, 이미지 2/3 Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: 7 단계, 이미지 3/3
    • Gently pull up on tab that connects the charging port to the motherboard
결론
다른 5명이 해당 안내서를 완성하였습니다.
Jonathan Romine
회원 가입일: 09/12/16
1,072 평판
안내서 2개 작성하였습니다
USF Tampa, Team 9-2, Lacy Fall 2016 USF Tampa, Team 9-2, Lacy Fall 2016 회원
USFT-LACY-F16S9G2
4 회원들
안내서 10개 작성하였습니다
댓글 3개
Thank you for your help. You are awesome :-)
Kim Williams - 답글
I did all of this and battery says “not charging” while plugged in. Replaced both battery and port.
Brandon Torzeski - 답글
Hey Thanks guys! I was interested in the data port / charging port flex cable replacement.
It could not be easier. Cheers folks.
Jim Kirkey
Jim Kirkey - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 19
전체 시간: 4,038
