필요한 것
Begin by separating the back panel from the screen glass assembly using the plastic opening tool.
Insert the plastic opening tool between the edge of the glass screen and the metal frame around the device.
The battery should be completely disconnected and the new one can be installed.
Just two things I’d like to add. In step 2, one can see where the bottom clips to the top with the mainboard, and it’s easier if one pries adjacent to those clips. Secondly, one shouldn’t tighten the screws for the battery too much, I tightened them till they were tight but ended up having to take it apart again and loosen them by around a turn or so. If they are too tight, they will warp the diffuser/reflector/light guide for the LCD panel and there’ll be brighter spots in the LCD screen. The screws originally have thread lock, so I guess if one isn’t confident the screws will stay in place it’s best to re-apply some, though as they are screwing into a plastic frame, the hope is that the plastic provides enough friction for the screw to remain in place.
다른 5명이 해당 안내서를 완성하였습니다.
댓글 3개
Thank you for your help. You are awesome :-)
I did all of this and battery says “not charging” while plugged in. Replaced both battery and port.
Hey Thanks guys! I was interested in the data port / charging port flex cable replacement.
It could not be easier. Cheers folks.
Jim Kirkey
Jim Kirkey - 답글
