주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab Pro 8.4 Motherboard Replacement
필요한 것
  1. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement, Battery: 1 단계, 이미지 1/1
    • Begin by separating the back panel from the screen glass assembly using the plastic opening tool.
    • Insert the plastic opening tool between the edge of the glass screen and the metal frame around the device.
  2. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: 2 단계, 이미지 2/2
    • Continue around the entire device until the back panel is completely separated from the screen.
  3. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: 3 단계, 이미지 1/2 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: 3 단계, 이미지 2/2
    • Remove the four 2.5mm Phillips #000 screws.
  4. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: 4 단계, 이미지 1/1
    • Gently pull up on the plastic tab that has red, blue and black wires that connects the battery to the motherboard.
  5. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: 5 단계, 이미지 1/1
    • The battery should be completely disconnected and the new one can be installed.
  6. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement, Motherboard: 6 단계, 이미지 1/3 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement, Motherboard: 6 단계, 이미지 2/3 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement, Motherboard: 6 단계, 이미지 3/3
    • Remove all the clips that are attached to the motherboard using your fingers or a nylon spudger.
  7. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: 7 단계, 이미지 1/3 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: 7 단계, 이미지 2/3 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: 7 단계, 이미지 3/3
    • There are four Phillips head screws (2.5mm) that need to be removed:
    • Two on the charging port, which is the small metallic piece at the bottom of the device.
    • There is one screw that is covered by a small green tape. The tape must be peeled off before the screw under can be removed.
    • The last screw is found on a speaker at the bottom right of the device. Once the screw is removed, the speaker must be removed as well.
  8. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: 8 단계, 이미지 1/3 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: 8 단계, 이미지 2/3 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: 8 단계, 이미지 3/3
    • There is a small wire that connects the motherboard to the bottom right corner.
    • Gently pull the end of the wire that attaches the motherboard to the device until the wire is disconnected.
    • After the cord is disconnected, the motherboard can be removed from the tablet by simply lifting it from the device.
결승점
다른 5명이 해당 안내서를 완성하였습니다.
victor johnson
회원 가입일: 10/05/16
242 평판
안내서 1개 작성함
USF Tampa, Team 9-2, Lacy Fall 2016 USF Tampa, Team 9-2, Lacy Fall 2016 회원
USFT-LACY-F16S9G2
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 18
전체 시간: 2,388
