주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement
필요한 것
  1. Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement, Stereo Speakers: 1 단계, 이미지 1/1
    • Begin by separating the back panel from the screen glass assembly using the plastic opening tool.
  2. Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: 2 단계, 이미지 2/2
    • Continue around the entire device until the back panel is completely separated from the screen.
  3. Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: 3 단계, 이미지 1/3 Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: 3 단계, 이미지 2/3 Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: 3 단계, 이미지 3/3
    • Use a Phillips #000 screwdriver to remove the 2.5mm Phillips head screw on the top part of the speaker.
  4. Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: 4 단계, 이미지 1/2 Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: 4 단계, 이미지 2/2
    • Using your fingers, carefully remove the tab that connects the speaker to the motherboard.
  5. Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: 5 단계, 이미지 1/3 Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: 5 단계, 이미지 2/3 Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: 5 단계, 이미지 3/3
    • Using your fingers, gently remove the speaker from its place.
  6. Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: 6 단계, 이미지 1/3 Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: 6 단계, 이미지 2/3 Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: 6 단계, 이미지 3/3
    • Use a Phillips #000 screwdriver to remove the 2.5mm Phillips head screw on top of the speaker.
  7. Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: 7 단계, 이미지 1/2 Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: 7 단계, 이미지 2/2
    • Using your fingers, lift the tab that connects the speaker to the mother board.
  8. Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: 8 단계, 이미지 1/1
    • Using a nylon spudger, gently lift the round piece that connects to the speaker and remove it from its place.
  9. Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: 9 단계, 이미지 1/2 Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: 9 단계, 이미지 2/2
결론
Mario Montoya
회원 가입일: 09/12/16
225 평판
안내서 2개 작성하였습니다
USF Tampa, Team 9-2, Lacy Fall 2016 USF Tampa, Team 9-2, Lacy Fall 2016 회원
USFT-LACY-F16S9G2
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 621
