주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab S 10.5 Headphone Jack Replacement
필요한 것
  1. Samsung Galaxy Tab S 10.5 Headphone Jack Replacement, Disassembling Galaxy Tab S 10.5 Back Cover: 1 단계, 이미지 1/2 Samsung Galaxy Tab S 10.5 Headphone Jack Replacement, Disassembling Galaxy Tab S 10.5 Back Cover: 1 단계, 이미지 2/2
    • Place the plastic opening tool into the SD card slot or charge port.
    • Try in an upward motion until you see a separation between the tablet and back cover.
  2. Samsung Galaxy Tab S 10.5 Headphone Jack Replacement: 2 단계, 이미지 1/1
    • Work around the entire device by sliding the plastic opening tool around the rim.
    • If this is the first time, it will be hard to separate the back cover from the tablet.
    • The clips are approximately 5 cm apart. While working around the device, the clips will make a dislocating sound when disconnected.
  3. Samsung Galaxy Tab S 10.5 Headphone Jack Replacement: 3 단계, 이미지 1/1
    • Remove the back cover once all links have been separated.
    • Be careful when touching any of the internal components of the tablet.
  4. Samsung Galaxy Tab S 10.5 Headphone Jack Replacement, Back Rim Cover: 4 단계, 이미지 1/3 Samsung Galaxy Tab S 10.5 Headphone Jack Replacement, Back Rim Cover: 4 단계, 이미지 2/3 Samsung Galaxy Tab S 10.5 Headphone Jack Replacement, Back Rim Cover: 4 단계, 이미지 3/3
    • Place the plastic opening tool in between the outer rim.
    • Move the tool in a downward motion to separate the 2 parts.
    • Run the tool along the rim to disconnect all connectors holding the outer rim to the back of the device.
  5. Samsung Galaxy Tab S 10.5 Headphone Jack Replacement: 5 단계, 이미지 1/1
    • Repeat this step for all four sides, then remove the rim.
  6. Samsung Galaxy Tab S 10.5 Headphone Jack Replacement, Headphone Jack: 6 단계, 이미지 1/1
    • Using the Phillips #00 screwdriver, remove the two screws holding the headphone jack.
  7. Samsung Galaxy Tab S 10.5 Headphone Jack Replacement: 7 단계, 이미지 1/1
    • Place the hook of a spudger on the backside of headphone jack and pop the headphone jack out.
결론
다른 2명이 해당 안내서를 완성하였습니다.
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 16
전체 시간: 586
