주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab S 8.4 Back Cover Replacement
필요한 것
  1. Samsung Galaxy Tab S 8.4 Back Cover Replacement, Back Cover: 1 단계, 이미지 1/2 Samsung Galaxy Tab S 8.4 Back Cover Replacement, Back Cover: 1 단계, 이미지 2/2
    • Place the plastic opening tool between the face of the display and rim of the back cover of the device.
    • Move the plastic opening tool in a downward motion until you see separation between the tablet and back cover.
  2. Samsung Galaxy Tab S 8.4 Back Cover Replacement: 2 단계, 이미지 1/1
    • By sliding the plastic opening tool around the rim of the device, carefully continue to pry apart the screen and back cover.
    • Try to separate evenly on all sides until the screen detaches from the device backing completely.
    • If this is the first time removing the back cover, it will be rather difficult to separate it from the tablet.
  3. Samsung Galaxy Tab S 8.4 Back Cover Replacement: 3 단계, 이미지 1/1
    • Remove the back cover after the entire rim is disconnected.
결론
다른 12명이 해당 안내서를 완성하였습니다.
Tara Fussell
회원 가입일: 10/01/15
984 평판
안내서 2개 작성하였습니다
Cal Poly, Team 12-15, Maness Fall 2015 Cal Poly, Team 12-15, Maness Fall 2015 회원
CPSU-MANESS-F15S12G15
4 회원들
안내서 12개 작성하였습니다
댓글 3개
This is great and the process works fine. The query is where does one purchase a new back cover
Alan - 답글
Hi, where can I buy the back cover of Samsung galaxy tab S 8.4. Tnx
Abe Madrigal - 답글
Hi, where can I buy the back cover of Samsung galaxy tab s 8.4. Ty
Abe Madrigal - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 16
30일 전: 59
전체 시간: 13,322
