주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement
필요한 것
  1. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement, Back Cover: 1 단계, 이미지 1/2 Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement, Back Cover: 1 단계, 이미지 2/2
    • Place the plastic opening tool between the face of the display and rim of the back cover of the device.
    • Move the plastic opening tool in a downward motion until you see separation between the tablet and back cover.
  2. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: 2 단계, 이미지 1/1
    • By sliding the plastic opening tool around the rim of the device, carefully continue to pry apart the screen and back cover.
    • Try to separate evenly on all sides until the screen detaches from the device backing completely.
    • If this is the first time removing the back cover, it will be rather difficult to separate it from the tablet.
  3. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: 3 단계, 이미지 1/1
    • Remove the back cover after the entire rim is disconnected.
  4. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement, Headphone Jack/Speakers Assembly: 4 단계, 이미지 1/2 Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement, Headphone Jack/Speakers Assembly: 4 단계, 이미지 2/2
    • Remove the two 2 mm Phillips #000 securing the headphone jack.
  5. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: 5 단계, 이미지 1/1
    • Disconnect the blue connector by gently popping it off of the motherboard with a plastic opening tool.
  6. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: 6 단계, 이미지 1/2 Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: 6 단계, 이미지 2/2
    • Use the metal spudger to pry from the top left corner of the headphone jack/lower speaker assembly.
    • Gently lift the headphone jack/lower speaker assembly free of the device.
  7. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: 7 단계, 이미지 1/1
    • Locate the top speaker.
    • Use a plastic opening tool to disconnect the green-gold upper speaker connector from the motherboard.
  8. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: 8 단계, 이미지 1/2 Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: 8 단계, 이미지 2/2
    • Use a spudger to pry the uper speaker up and away from the device.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Trent Chapman
회원 가입일: 10/01/15
1,378 평판
안내서 3개 작성하였습니다
Cal Poly, Team 12-15, Maness Fall 2015 Cal Poly, Team 12-15, Maness Fall 2015 회원
CPSU-MANESS-F15S12G15
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 13
전체 시간: 3,336
