주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab S 8.4 Micro USB Port Replacement
필요한 것
  1. Samsung Galaxy Tab S 8.4 Micro USB Port Replacement, Back Cover: 1 단계, 이미지 1/2 Samsung Galaxy Tab S 8.4 Micro USB Port Replacement, Back Cover: 1 단계, 이미지 2/2
    • Place the plastic opening tool between the face of the display and rim of the back cover of the device.
    • Move the plastic opening tool in a downward motion until you see separation between the tablet and back cover.
  2. Samsung Galaxy Tab S 8.4 Micro USB Port Replacement: 2 단계, 이미지 1/1
    • By sliding the plastic opening tool around the rim of the device, carefully continue to pry apart the screen and back cover.
    • Try to separate evenly on all sides until the screen detaches from the device backing completely.
    • If this is the first time removing the back cover, it will be rather difficult to separate it from the tablet.
  3. Samsung Galaxy Tab S 8.4 Micro USB Port Replacement: 3 단계, 이미지 1/1
    • Remove the back cover after the entire rim is disconnected.
  4. Samsung Galaxy Tab S 8.4 Micro USB Port Replacement, Micro USB Port: 4 단계, 이미지 1/2 Samsung Galaxy Tab S 8.4 Micro USB Port Replacement, Micro USB Port: 4 단계, 이미지 2/2
    • Remove the two 4 mm Phillips #000 screws securing the micro USB port.
  5. Samsung Galaxy Tab S 8.4 Micro USB Port Replacement: 5 단계, 이미지 1/2 Samsung Galaxy Tab S 8.4 Micro USB Port Replacement: 5 단계, 이미지 2/2
    • Using the plastic opening tool, disconnect the charge port from the motherboard.
    • Once disconnected, lift to remove the charging port.
결론
다른 32명이 해당 안내서를 완성하였습니다.
Trent Chapman
회원 가입일: 10/01/15
1,378 평판
안내서 3개 작성하였습니다
Cal Poly, Team 12-15, Maness Fall 2015 Cal Poly, Team 12-15, Maness Fall 2015 회원
CPSU-MANESS-F15S12G15
4 회원들
안내서 12개 작성하였습니다
댓글 6개
It is so amazing and it works!
alva chan - 답글
Thanks a lot!
You make me a big economy by doing this myself with YOUR instructions !
Raphael
refelo123 - 답글
What model number is this device specifically? It says WiFi, but I have the same one from a network carrier. Would this charging port work for that? Model sm-707v is the one that I have.
tailoredtoteach - 답글
Thanks for the instructions, it looks simple , so I ordered the docking assembly and I replace it by myself.
You saved me a lot of money, thanks again!
wim-zelf - 답글
With these instructions I ordered part from Amazon and replaced charging port and tablet charges again. Thanks!
Philip Holly - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 51
전체 시간: 15,348
