소개
If the device has been dropped or damaged, it is likely that the rear-facing camera may become cracked or scratched. This guide will show you how to replace the rear-facing camera.
필요한 것
Place the plastic opening tool between the face of the display and rim of the back cover of the device.
Move the plastic opening tool in a downward motion until you see separation between the tablet and back cover.
Gently pry the camera connector away from the motherboard with a plastic opening tool or your fingers.
Lift the rear-facing camera module up and away from the device.
다른 2명이 해당 안내서를 완성하였습니다.
