주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement
필요한 것
  1. Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement, Back Cover: 1 단계, 이미지 1/2 Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement, Back Cover: 1 단계, 이미지 2/2
    • Place the plastic opening tool between the face of the display and rim of the back cover of the device.
    • Move the plastic opening tool in a downward motion until you see separation between the tablet and back cover.
  2. Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement: 2 단계, 이미지 1/1
    • By sliding the plastic opening tool around the rim of the device, carefully continue to pry apart the screen and back cover.
    • Try to separate evenly on all sides until the screen detaches from the device backing completely.
    • If this is the first time removing the back cover, it will be rather difficult to separate it from the tablet.
  3. Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement: 3 단계, 이미지 1/1
    • Remove the back cover after the entire rim is disconnected.
  4. Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement, Rear Facing Camera: 4 단계, 이미지 1/2 Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement, Rear Facing Camera: 4 단계, 이미지 2/2
    • Gently pry the camera connector away from the motherboard with a plastic opening tool or your fingers.
    • Lift the rear-facing camera module up and away from the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Trent Chapman
회원 가입일: 10/01/15
1,378 평판
안내서 3개 작성하였습니다
Cal Poly, Team 12-15, Maness Fall 2015 Cal Poly, Team 12-15, Maness Fall 2015 회원
CPSU-MANESS-F15S12G15
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 1,411
