주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab S2 8.0 Camera Replacement
필요한 것
  1. Samsung Galaxy Tab S2 8.0 Camera Replacement, Screen: 1 단계, 이미지 1/1
    • Working on a device that is turned on may yield an electric shock. Make sure your device is turned off before working on it.
    • Apply heat using an iFixit iOpener or another heating gun in order to weaken the adhesive around the edges of the screen.
  2. Samsung Galaxy Tab S2 8.0 Camera Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Tab S2 8.0 Camera Replacement: 2 단계, 이미지 2/2
    • Insert the plastic opening tool into the gap between the screen and tablet in the location where you want to start removing the screen.
    • Put an opening pick in the gap created, in between the screen and the panel.
    • Repeat all around device, putting 2 picks on top and bottom, and one on each side.
  3. Samsung Galaxy Tab S2 8.0 Camera Replacement: 3 단계, 이미지 1/2 Samsung Galaxy Tab S2 8.0 Camera Replacement: 3 단계, 이미지 2/2
    • Carefully remove the small suction cup from the corner without moving the screen.
    • Place the small suction cup in the center of the screen and lift to remove screen.
    • Make sure to separate all glue under the middle parts of the screen as well as the edges - use a thin stiff card to slice through it. Avoid the ribbon cable. Do not attempt to lift the screen until all glue is separated.
    • The screen is still connected to the rest of the device by a cable, so don't pull the screen up too quickly.
  4. Samsung Galaxy Tab S2 8.0 Camera Replacement: 4 단계, 이미지 1/1
    • Place the plastic opening tool underneath the ribbon cable connecting the screen to the tablet.
    • Carefully lift the plastic opening tool to detach the ribbon from the tablet.
    • Make sure to discharge any static electricity by touching a grounded metal object, like a quarter, before touching the inside of the device.
  5. Samsung Galaxy Tab S2 8.0 Camera Replacement: 5 단계, 이미지 1/1
    • The screen is now detached from the rest of the tablet.
  6. Samsung Galaxy Tab S2 8.0 Camera Replacement, Camera: 6 단계, 이미지 1/1
    • Remove the 13 3mm screws from around the edges of the board using a Phillips #1 screwdriver head.
  7. Samsung Galaxy Tab S2 8.0 Camera Replacement: 7 단계, 이미지 1/2 Samsung Galaxy Tab S2 8.0 Camera Replacement: 7 단계, 이미지 2/2
    • Use the plastic opening tool to lift and remove the plastic motherboard cover.
  8. Samsung Galaxy Tab S2 8.0 Camera Replacement: 8 단계, 이미지 1/2 Samsung Galaxy Tab S2 8.0 Camera Replacement: 8 단계, 이미지 2/2
    • Use the plastic opening tool to detach the camera's ribbon from the motherboard.
  9. Samsung Galaxy Tab S2 8.0 Camera Replacement: 9 단계, 이미지 1/2 Samsung Galaxy Tab S2 8.0 Camera Replacement: 9 단계, 이미지 2/2
    • Carefully remove the camera from the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jonathan Wood
회원 가입일: 04/18/17
1,011 평판
안내서 5개 작성하였습니다
Cal Poly, Team S17-G1, Banghart Spring 2017 Cal Poly, Team S17-G1, Banghart Spring 2017 회원
CPSU-BANGHART-S17S17G1
5 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 11
전체 시간: 887
