주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab S2 Battery Replacement
필요한 것
  1. Samsung Galaxy Tab S2 Battery Replacement, Screen: 1 단계, 이미지 1/1
    • Working on your device while it is turned on may result in an electric shock. Be sure to shut down and unplug your device before you begin.
    • Removing the screen may be difficult due to strong adhesives.
    • Apply heat to all the seams of the device using an iFixit iOpener or heat gun in order to loosen the adhesive around the edges of the screen.
    m.E. wichtig vorher die Kartenhalter für SIM und SD entfernen, sonst löst sich der Kontakt unkontrolliert bei Schritt 6.
    Frank Huebner - 답글
    You make no mention of re-Glueing the screen, just applying the steps in reverse order - does that mean simply applying heat again will re-glue the components from the residue?
    Robin Penny - 답글
    i replaced the battery, the sticky tape did hold up again, but if you replace the screen it depends on whate side the tape sticks to. On ine the most part of the tape stuck to the screen.
    Steffen Hahn -
    I know its 2020 but i cracked my screen and idk if its on or not
    benjamin burkowski_FaZe - 답글
  2. Samsung Galaxy Tab S2 Battery Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Tab S2 Battery Replacement: 2 단계, 이미지 2/2
    • Insert the plastic opening tool into the gap on the side of the tablet, near a corner where you want to start removing the screen.
    • Place the small suction cup on the screen near the corner that the plastic opening tool is placed.
    • Lift the small suction cup up while pushing down with the plastic opening tool to remove screen (you may need to have someone else hold the device down for proper leverage).
    • A ribbon cable is attached to the back of the screen. Avoid lifting or moving the screen more than 3-4 inches before disconnecting the ribbon cable or you could damage the device.
    The lower portion of the screen is glued to the body. The screen is unable to be completely removed.
    Chad Naville-Cook - 답글
    That blue plastic tool doesn’t work
    Jarred - 답글
    starte oben, unten verhindert eine Nase an dem Audioanschluß das erste anheben.
    start upside, downside a nose at the audio connector prevents the first lifting.
    Frank Huebner - 답글
  3. Samsung Galaxy Tab S2 Battery Replacement: 3 단계, 이미지 1/1
    • A piece of silver tape is placed over the gold ribbon cable connecting the screen to the tablet.
    • Use the tweezers to carefully remove the silver tape.
    Hi. My SM T 815 (Tab 2) flickers and switches off. The screen is still fine. Well atleast it looks fine. But it doesn’t switch on. Could it be the reflex cable? Why is it doing this? And how can it be solved?
    Thabo - 답글
  4. Samsung Galaxy Tab S2 Battery Replacement: 4 단계, 이미지 1/2 Samsung Galaxy Tab S2 Battery Replacement: 4 단계, 이미지 2/2
    • With the plastic opening tool gently lift to disconnect the gold ribbon cable that attaches the screen to the base tablet.
  5. Samsung Galaxy Tab S2 Battery Replacement, Panel Replacement: 5 단계, 이미지 1/2 Samsung Galaxy Tab S2 Battery Replacement, Panel Replacement: 5 단계, 이미지 2/2
    • Remove the nineteen 3mm Phillips #1 screws.
    make sure to remove the 2 black screws on the frame. i fix it doesnt say to take those off. nearly damaged the frame
    bryzz tortello - 답글
  6. Samsung Galaxy Tab S2 Battery Replacement: 6 단계, 이미지 1/2 Samsung Galaxy Tab S2 Battery Replacement: 6 단계, 이미지 2/2
    • Pry open the next layer of the device using the plastic opening tool.
    • Even though the device separates along the outside edge, using the inside edge (as pictured) may help with leverage.
    -Zuvor unbedingt SIM Karte u microSD entfernen, sonst bleibt der Elekronikpart am Gehäuse fest und das Flachbandkabel davon kann beschädigt werden!
    -Lösen des unteren Teils des Innengehäuses zum Schluss, da Ladebuchse eine Nase hat und sich erst löst wenn man es schräg nach unten abhebt.
    Michael - 답글
  7. Samsung Galaxy Tab S2 Battery Replacement, Battery: 7 단계, 이미지 1/2 Samsung Galaxy Tab S2 Battery Replacement, Battery: 7 단계, 이미지 2/2
    • Remove the four black 3 mm Phillips #1 screws that hold the battery in place.
    I had an issue with charging of Tab S2. When you connect it to a charger, it detects it, charges for 2 seconds, stops charging for 7-8 seconds and charges again for 2 seconds. It keeps going on in circles. It actually did charge to 100%, but it could take a whole day. I watched some videos online and there’s a way to get to it from behind. I got myself tools and a new battery, thinking it could be a battery problem. Long story short, there are flat cables reaching behind from volume buttons glued to the back cover and they use pressure from the back cover to make contact. Of course, I broke the flat cable. Most of the back cover is held in place by clips, but right next to the round metal looking “buttons” there is some extra strong glue (north of those “buttons”). Samsung didn’t want to make repairs easy and simple :/.
    sbelosevic - 답글
  8. Samsung Galaxy Tab S2 Battery Replacement: 8 단계, 이미지 1/1
    • Use a plastic opening tool to lift the black flap on the ZIF connector located in the top left corner of the device.
    • Once the connector is unlocked, pull the ribbon cable out with tweezers.
    • This cable does not need to be completely removed, only one side is enough to allow the battery to be taken out.
    I did not find it necessary to detach this cable. The battery slid out from under it easily.
    Yishai Sered - 답글
  9. Samsung Galaxy Tab S2 Battery Replacement: 9 단계, 이미지 1/2 Samsung Galaxy Tab S2 Battery Replacement: 9 단계, 이미지 2/2
    • Using the plastic opening tool remove the cable that connects the battery to the device.
    • Now you can remove the battery with your hands.
    I was proud of myself. It was for me as easy as this, videos online showed more difficulty . The suction cup and the jimmy was enough to open the screen. Do watch some videos online to see all the parts you could damage and on how to open the different cable connectors as they are and work different.
    Rene vandockum - 답글
결론
다른 38명이 해당 안내서를 완성하였습니다.
Jovina Martinez
회원 가입일: 01/20/16
2,084 평판
안내서 7개 작성하였습니다
USF Tampa, Team 10-4, Remmell Spring 2016 USF Tampa, Team 10-4, Remmell Spring 2016 회원
USFT-REMMELL-S16S10G4
4 회원들
안내서 18개 작성하였습니다
댓글 17개
Thanks for the guide. At least Apple has an out-of-warranty service for the battery replacement of $99. To replace this battery, with a dubious quality 3rd party battery as I don't think it's possible to buy a OEM Samsung battery, looks like a disaster waiting to happen, not worth the effort or time, I returned mine to Samsung after seeing this guide. I'm not suggesting Apple is a saint for the $99 replacement, but at least they will do it with an OEM battery.
adobepro - 답글
Can you give a link to this apple offer for an ipad ?
stagiaireekimia -
after I did this, my display was dead. Nothing showed. Tablet was receiving email notifications and lights worked.. just a blank screen. What happened?
Mr Betatester - 답글
You crackedbthe oled panel
Biuro Lul -
The Battery is accessible from the rear panel!
**It will damage two plastic mounts on the rear panel, however an appropriate adhesive (GO2 by loctite) or bonding tape, will fix this**
1: On the back, there is a clearly visible outline of a plastic cover.
2: Starting from the side opposite the “Little round button things” on the back, run a case opening tool slowly around the seam, popping the small plastic hooks. Do all three sides EXCEPT the side with the round button things.
3: When you get to this forth side, carefully and slowly work around the round buttons, working the case up. Then flex up the back plastic from the side you have already removed, and using a long case tool, insert it in all the way past the battery to the inside edge of the round button things and gently twist here. The tabs will pop and that side will release. Repeat for the other snap button.
4: Your back cover is now removed and you have access directly to the battery !
Do this If you are not confident lifting a $350 dollar screen…
tek Gadget - 답글
The “two plastic mounts” are not “snap buttons.” There are two nuts mounted on the back panel, and they are attached by screws from the front. The process described in this comment will at least separate the nuts from the back panel. The back panel itself may crack, or even the nut and its attachment may remain connected to screw and a hole be formed in the back panel.
The proper procedure is to remove the display as shown here. Then remove the black screws connecting to the back panel, instead of all the silver screws in step 5. Then use an opening tool on the back panel and remove it safely to access the battery from the back side.
Unfortunately it’s hard to find the adhesive cutout needed to properly re-attach the display after removal (I only found the part GH81-13867A on eBay from Europe, about $28 with shipping). And even then it would be hard to remove the old adhesive well. We’ll likely have to reply on reuse of the old adhesive, and the display will not longer be attached perfectly as before.
Yishai Sered -
Yep, this is the much easier and safer way to do it.
Blair Skinner -
Many tanks tek Gadget!
Antonio Zanella - 답글
Is this possible without breaking the screen ? or does it always break when removing it
Rolo - 답글
Please take care of the Comment of tek gadget!!! Because the photos are horrible wrong. You MUST turn it and get of the cover of of the backside!!
tek gadget explained it very well on 31.10.2017!!
Rudolf Pezzei - 답글
Failed to mention that if you take the screen off, there are 4 ribbon cables on the left side. If you go around with the guitar pick looking tool, you will rip right through them. Just destroyed my tablet.
Russell Streitz - 답글
Inside of my tab S2 looked slightly different (probably just a newer model) and yes there are ribbon cables to be aware of; however, I was able to replace my battery following this guide. It wan’t easy though!
Chris Batchelor-McAuley - 답글
Why not just remove the rear cover instead? Easy access and no chance of screwing up the screen, adding to your replacement costs?
Gregg Stanley - 답글
If following the guide as listed. Step 6, you may want to pry on sides/top. For the bottom the headphone jack plug slightly juts out and its easier to slide out than work against it with fear of breaking.
Jeremy Smith - 답글
Hi, ich habe hier ein samsung sm-t810 , jetzt gibt es 2 verschiedene wege. warum nicht durch die klappe hinten öffnen?
liebe Grüße
michael buss - 답글
I find it way easier to remove the back panel, and break the two nuts.
The nuts are close to the snap button for the flip cover. By using the metal spudger, you can get a proper leverage close to the nuts, and get a clean break.
To do this, I detached all the clips I could, to the point where the cover is only attached by the two nuts. Then, to break a nut, I insert the spudger from the opposite side. I press the tablet against the table (not the cover...), and I lift the spudger until the nut break. Repeat with the second nut.
Then you gain access to the battery.
You can put back the cover without any glue or whatever, it already holds enough thanks to the numerous clips.
Adrien Horgnies - 답글
댓글 쓰기
조회 통계:
24 시간 전: 23
7일 전: 141
30일 전: 684
전체 시간: 118,852
