주요 콘텐츠로 건너뛰기
Samsung Galaxy Tab S2 Panel Replacement
단지 전제 조건
이 안내서는 다른 안내서의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. Samsung Galaxy Tab S2 Panel Replacement, Screen: 1 단계, 이미지 1/1
    • Working on your device while it is turned on may result in an electric shock. Be sure to shut down and unplug your device before you begin.
    • Removing the screen may be difficult due to strong adhesives.
    • Apply heat to all the seams of the device using an iFixit iOpener or heat gun in order to loosen the adhesive around the edges of the screen.
  2. Samsung Galaxy Tab S2 Panel Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Tab S2 Panel Replacement: 2 단계, 이미지 2/2
    • Insert the plastic opening tool into the gap on the side of the tablet, near a corner where you want to start removing the screen.
    • Place the small suction cup on the screen near the corner that the plastic opening tool is placed.
    • Lift the small suction cup up while pushing down with the plastic opening tool to remove screen (you may need to have someone else hold the device down for proper leverage).
    • A ribbon cable is attached to the back of the screen. Avoid lifting or moving the screen more than 3-4 inches before disconnecting the ribbon cable or you could damage the device.
  3. Samsung Galaxy Tab S2 Panel Replacement: 3 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • A piece of silver tape is placed over the gold ribbon cable connecting the screen to the tablet.
    • Use the tweezers to carefully remove the silver tape.
  4. Samsung Galaxy Tab S2 Panel Replacement: 4 단계, 이미지 1/2 Samsung Galaxy Tab S2 Panel Replacement: 4 단계, 이미지 2/2
    • With the plastic opening tool gently lift to disconnect the gold ribbon cable that attaches the screen to the base tablet.
  5. Samsung Galaxy Tab S2 Panel Replacement, Panel Replacement: 5 단계, 이미지 1/2 Samsung Galaxy Tab S2 Panel Replacement, Panel Replacement: 5 단계, 이미지 2/2
    • Remove the nineteen 3mm Phillips #1 screws.
  6. Samsung Galaxy Tab S2 Panel Replacement: 6 단계, 이미지 1/2 Samsung Galaxy Tab S2 Panel Replacement: 6 단계, 이미지 2/2
    • Pry open the next layer of the device using the plastic opening tool.
    • Even though the device separates along the outside edge, using the inside edge (as pictured) may help with leverage.
결론
Jovina Martinez
회원 가입일: 01/20/16
2,099 평판
안내서 7개 작성하였습니다
USF Tampa, Team 10-4, Remmell Spring 2016 USF Tampa, Team 10-4, Remmell Spring 2016 회원
USFT-REMMELL-S16S10G4
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 457
