소개
Use this guide to replace a cracked or malfunctioning display on your Samsung Galaxy Tab S3 tablet (identified with model number SM-T820).
The display assembly is the output component to present information and is made up of the glass panel, digitizer, and AMOLED display sandwiched together. Your display may need to be replaced if the glass cracks or is broken because this will affect its touch screen capabilities. It could also experience something called “screen burn-in” that happens on AMOLED displays. “Screen burn-in” is when some of the individual light-emitting pixels powering the display will dim the more they are used, causing uneven lighting and colors.
In step 1 of this guide, you will need to use the iOpener, which is a microwavable heating tool used to loosen adhesive attached to the display. Carefully follow the iOpener heating instructions to avoid burning yourself. If your display is shattered, follow this guide to reinforce your screen to avoid injury until you replace the display. Make sure to power off your laptop completely and disconnect from any external power source prior to beginning this guide.
필요한 것
To soften the adhesive holding the tablet together, heat up the edges of the glass panel using a heated iOpener on the edge of the device. Alternatively you can use a heat gun to loosen the adhesive.
Leave the iOpener on edge for two minutes.
Place a suction cup near edge that you heated up with the iOpener.
Press down on the suction cup to create a seal, and pull up with force to create a separation between the display and the midframe.
Use an opening tool to split apart the glass panel from the midframe.
Bonjour, pour moi il est IMPÉRATIF d’opérer l’ouverture par le bord droit comme indiqué sur le tuto car de l’autre coté les nappes du LCD ne sont qu’à 3mm du bord et peuvent etre abimée comme je l’ai fait lors du décollage.
이 단계에 사용된 도구:Plastic Cards$2.99
As you continue along the edge using the opening tool, use a plastic card to keep the glass separate from the midframe.
For this part I recommend to insert the tools only on top, bottom and right side. Then lift the screen as shown in the pictures in step 4. The left side has the light ribbons for the display too close to the edge and they are really thin. I just broke the four of them in my screen :(
Repeat steps 3 through 7 to remove the rear glass panel on the opposite side of the device.
To reassemble your device, follow these instructions in reverse order. If you have removed too much adhesive, you may need to apply more during the reassembly process.
다른 7명이 해당 안내서를 완성하였습니다.
댓글 5개
What if the digitizer is ok and only the glass cover is cracked
If my screen freezing exactly half, can that be the connection cable damaged.? It's look like it happens every time I touch or hold the corner where the volume and power buttons are. Never dropped it.
Lena Clark - 답글
I also have the same issue
How your issue was resolved.
Ashwin -
There is no reason to remove the screen while replacing a battery.
Nick Youngstrom - 답글
Agreed , just remove back and warm up. Dont remove screen, is $220 to replace off ebay.
Phenix City - 답글
