소개
If you have damaged your Galaxy Tab S3's camera sensor or image stabilization, you will need to replace the camera module. This guide will show you how to properly remove and replace the cameras on the rear of the device.
If you notice that the camera lens is scratched, you will need to replace either the display assembly (front camera) or the rear glass panel (rear camera). A scratch on the camera's outer lens does not constitute damage to the module itself.
필요한 것
To soften the adhesive holding the tablet together, heat up the edges of the glass panel using a heated iOpener on the edge of the device. Alternatively you can use a heat gun to loosen the adhesive.
Leave the iOpener on edge for two minutes.
Place a suction cup near edge that you heated up with the iOpener.
Press down on the suction cup to create a seal, and pull up with force to create a separation between the display and the midframe.
Use an opening tool to split apart the glass panel from the midframe.
Bonjour, pour moi il est IMPÉRATIF d’opérer l’ouverture par le bord droit comme indiqué sur le tuto car de l’autre coté les nappes du LCD ne sont qu’à 3mm du bord et peuvent etre abimée comme je l’ai fait lors du décollage.
이 단계에 사용된 도구:Plastic Cards$2.99
As you continue along the edge using the opening tool, use a plastic card to keep the glass separate from the midframe.
For this part I recommend to insert the tools only on top, bottom and right side. Then lift the screen as shown in the pictures in step 4. The left side has the light ribbons for the display too close to the edge and they are really thin. I just broke the four of them in my screen :(
Repeat steps 3 through 7 to remove the rear glass panel on the opposite side of the device.
Use a Phillips #000 screwdriver to unscrew the five screws securing the battery, and the twenty-two screws surrounding the midframe.
Flip over the device, and carefully push the Rear Camera out of its framing using the spudger.
To reassemble your device, follow these instructions in reverse order. If you have removed too much adhesive, you may need to apply more during the reassembly process.
다른 2명이 해당 안내서를 완성하였습니다.
There is no reason to remove the screen while replacing a battery.
Nick Youngstrom - 답글
Agreed , just remove back and warm up. Dont remove screen, is $220 to replace off ebay.
Phenix City - 답글
