주요 콘텐츠로 건너뛰기
Samsung Galaxy TabPro S Front-Facing Camera Replacement
필요한 것
  1. Samsung Galaxy TabPro S Front-Facing Camera Replacement, Front-Facing Camera: 1 단계, 이미지 1/2 Samsung Galaxy TabPro S Front-Facing Camera Replacement, Front-Facing Camera: 1 단계, 이미지 2/2
    • Remove the back of the tablet by prying the plastic back using a flat tool.
    • When the tool has been inserted under the back, slide it all the way around the tablet to fully unclip it.
  2. Samsung Galaxy TabPro S Front-Facing Camera Replacement: 2 단계, 이미지 1/2 Samsung Galaxy TabPro S Front-Facing Camera Replacement: 2 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Once the back has been removed, disconnect all cables using a pair of tweezers to avoid damaging any components.
    • Once the cables have been disconnected, remove the battery using a flat plastic tool (not the metal spudger).
  3. Samsung Galaxy TabPro S Front-Facing Camera Replacement: 3 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to remove the screws that secure the motherboard.
    • Remove the metal plate once the screws are gone and the motherboard will be ready to be replaced.
  4. Samsung Galaxy TabPro S Front-Facing Camera Replacement: 4 단계, 이미지 1/2 Samsung Galaxy TabPro S Front-Facing Camera Replacement: 4 단계, 이미지 2/2
    • Remove motherboard by prying it up with a flat plastic opening tool (not metal spudger).
    • Be sure that all components have been disconnected beforehand, especially the front-facing camera (located above the motherboard in the top center of the frame).
  5. Samsung Galaxy TabPro S Front-Facing Camera Replacement: 5 단계, 이미지 1/2 Samsung Galaxy TabPro S Front-Facing Camera Replacement: 5 단계, 이미지 2/2
    • Once the camera has been disconnected from the motherboard, it can be removed using a pair of pliers.
결론
Mitchell Caister
회원 가입일: 03/31/22
328 평판
안내서 3개 작성하였습니다
IUPUI, Team 3-4, Harley Spring 2022 IUPUI, Team 3-4, Harley Spring 2022 회원
IUPUI-HARLEY-S22S3G4
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 13
전체 시간: 283
