주요 콘텐츠로 건너뛰기
Samsung Galaxy TabPro S Rear Facing Camera Replacement
필요한 것
  1. Samsung Galaxy TabPro S Rear Facing Camera Replacement, Rear Facing Camera: 1 단계, 이미지 1/1
    • Place the device face down on a flat work surface.
  2. Samsung Galaxy TabPro S Rear Facing Camera Replacement: 2 단계, 이미지 1/2 Samsung Galaxy TabPro S Rear Facing Camera Replacement: 2 단계, 이미지 2/2
    • Heat the iOpener in the microwave for 30 seconds. Then place it on each side for 20 seconds in order to loosen the adhesive sealing on the device.
  3. Samsung Galaxy TabPro S Rear Facing Camera Replacement: 3 단계, 이미지 1/3 Samsung Galaxy TabPro S Rear Facing Camera Replacement: 3 단계, 이미지 2/3 Samsung Galaxy TabPro S Rear Facing Camera Replacement: 3 단계, 이미지 3/3
    • Using the plastic spudger, open up the back of the device.
  4. Samsung Galaxy TabPro S Rear Facing Camera Replacement: 4 단계, 이미지 1/1
    • Locate the camera and its corresponding connecting port.
  5. Samsung Galaxy TabPro S Rear Facing Camera Replacement: 5 단계, 이미지 1/3 Samsung Galaxy TabPro S Rear Facing Camera Replacement: 5 단계, 이미지 2/3 Samsung Galaxy TabPro S Rear Facing Camera Replacement: 5 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Using tweezers carefully peel off the sticker.
  6. Samsung Galaxy TabPro S Rear Facing Camera Replacement: 6 단계, 이미지 1/2 Samsung Galaxy TabPro S Rear Facing Camera Replacement: 6 단계, 이미지 2/2
    • Using the black nylon spudger, flip the top half of the connecting port downward until you hear a click.
  7. Samsung Galaxy TabPro S Rear Facing Camera Replacement: 7 단계, 이미지 1/1
    • Proceed to lift up the camera out of its resting position.
  8. Samsung Galaxy TabPro S Rear Facing Camera Replacement: 8 단계, 이미지 1/2 Samsung Galaxy TabPro S Rear Facing Camera Replacement: 8 단계, 이미지 2/2
    • Simply pull the camera parallel to the device out of its connecting port.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jyotsna Gone
회원 가입일: 02/20/17
515 평판
안내서 2개 작성하였습니다
USF Tampa, Team 1-2, Sullivan Spring 2017 USF Tampa, Team 1-2, Sullivan Spring 2017 회원
USFT-SULLIVAN-S17S1G2
4 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 1,560
