주요 콘텐츠로 건너뛰기
Samsung Galaxy TabPro S Screen Replacement
필요한 것
  1. Samsung Galaxy TabPro S Screen Replacement, Screen: 1 단계, 이미지 1/1
    • Apply heat around the screen to loosen the glue holding in the screen. A heat gun would be preferable as it needs to get relatively warm.
  2. Samsung Galaxy TabPro S Screen Replacement: 2 단계, 이미지 1/1
    • Attach the small suction cup near the edge of the screen.
    • Pry in between the screen and the frame with a plastic spudger.
    • Pull up with the suction cup while prying and the screen should begin gently disconnecting.
    • Use the spudger on all edges of the tablet between the screen and the frame.
    • The screen should release.
  3. Samsung Galaxy TabPro S Screen Replacement: 3 단계, 이미지 1/1
    • Disconnect the thick cable from the motherboard
    • Disconnect the golden cable from the motherboard
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Mitchell Caister
회원 가입일: 03/31/22
328 평판
안내서 3개 작성하였습니다
IUPUI, Team 3-4, Harley Spring 2022 IUPUI, Team 3-4, Harley Spring 2022 회원
IUPUI-HARLEY-S22S3G4
3 회원들
안내서 3개 작성하였습니다
댓글 한 개
Where to find a replacement screen for a 2017 Samsung tab S pro 12 inch ?!?!?
ori gosi - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 38
전체 시간: 807
