주요 콘텐츠로 건너뛰기
Samsung Galaxy Victory 4G Motherboard Replacement
필요한 것
  1. Samsung Galaxy Victory 4G Motherboard Replacement, Motherboard: 1 단계, 이미지 1/3 Samsung Galaxy Victory 4G Motherboard Replacement, Motherboard: 1 단계, 이미지 2/3 Samsung Galaxy Victory 4G Motherboard Replacement, Motherboard: 1 단계, 이미지 3/3
    • Place phone face down. Ensure the side with the display screen is not facing you.
    • Locate battery door and slide open.
    • Remove battery.
  2. Samsung Galaxy Victory 4G Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove the 7 Phillips 3.93 mm labeled screws by using the Phillips #00 Precision Screwdriver.
  3. Samsung Galaxy Victory 4G Motherboard Replacement: 3 단계, 이미지 1/1
    • Use the plastic opening tool to pry open the back cover.
    • Insert the tool into the SD card slot and pry around the entire phone.
  4. Samsung Galaxy Victory 4G Motherboard Replacement: 4 단계, 이미지 1/1
    • Remove one Phillips 3.93 mm screw from bottom center of the phone.
  5. Samsung Galaxy Victory 4G Motherboard Replacement: 5 단계, 이미지 1/3 Samsung Galaxy Victory 4G Motherboard Replacement: 5 단계, 이미지 2/3 Samsung Galaxy Victory 4G Motherboard Replacement: 5 단계, 이미지 3/3
    • Carefully disconnect 3 ribbons at the shown location. To remove, place tool under the ribbon and pull slowly to avoid tearing.
  6. Samsung Galaxy Victory 4G Motherboard Replacement: 6 단계, 이미지 1/2 Samsung Galaxy Victory 4G Motherboard Replacement: 6 단계, 이미지 2/2
    • Pull the motherboard back and out to the left. Make sure the motherboard is faced straight up, as shown in the photo.
    • Place your tool under the labeled area and pull gently to detach the ribbon cable from the motherboard.
    • At this point the motherboard should be completely detached from the rest of the phone.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Zhao
회원 가입일: 09/23/14
251 평판
안내서 2개 작성하였습니다
USF Tampa, Team 15-3, Remmell Fall 2014 USF Tampa, Team 15-3, Remmell Fall 2014 회원
USFT-REMMELL-F14S15G3
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 1,612
