소개
The motherboard controls a majority of the functions on your phone. Go ahead and dive into this guide for detailed steps on how to remove the motherboard on your device.
필요한 것
Place phone face down. Ensure the side with the display screen is not facing you.
Locate battery door and slide open.
Remove battery.
Pull the motherboard back and out to the left. Make sure the motherboard is faced straight up, as shown in the photo.
Place your tool under the labeled area and pull gently to detach the ribbon cable from the motherboard.
At this point the motherboard should be completely detached from the rest of the phone.
다른 6명이 해당 안내서를 완성하였습니다.
