주요 콘텐츠로 건너뛰기
Samsung Galaxy View Battery Replacement
필요한 것
  1. Samsung Galaxy View Battery Replacement, Kickstand: 1 단계, 이미지 1/1
    • Place the device on a hard flat surface with its screen facing downwards.
    • Rotate the the kickstand so that the handle grip hole is up in the air and not touching the back of the tablet.
  2. Samsung Galaxy View Battery Replacement: 2 단계, 이미지 1/3 Samsung Galaxy View Battery Replacement: 2 단계, 이미지 2/3 Samsung Galaxy View Battery Replacement: 2 단계, 이미지 3/3
    • Stick the pointy end of the spudger into the circular opening of the leftmost metallic latch.
    • With the spudger still inserted, pry the spudger to the right pushing the latch opening along with it.
    • Once the latch is moved to the right, pull up on the left side of the kickstand, releasing it from the back of the tablet.
    • Repeat the previous steps for the rightmost latch, and then lift the kickstand off the back of the tablet.
  3. Samsung Galaxy View Battery Replacement, Battery: 3 단계, 이미지 1/2 Samsung Galaxy View Battery Replacement, Battery: 3 단계, 이미지 2/2
    • Check the device is completely turned off.
    • Slide open the SD compartment tab, and remove the SD card to ensure all data is saved.
  4. Samsung Galaxy View Battery Replacement: 4 단계, 이미지 1/3 Samsung Galaxy View Battery Replacement: 4 단계, 이미지 2/3 Samsung Galaxy View Battery Replacement: 4 단계, 이미지 3/3
    • Remove the 4 screws (4 mm in length) using the Phillips #0 screwdriver.
  5. Samsung Galaxy View Battery Replacement: 5 단계, 이미지 1/3 Samsung Galaxy View Battery Replacement: 5 단계, 이미지 2/3 Samsung Galaxy View Battery Replacement: 5 단계, 이미지 3/3
    • Insert the plastic opening tool between the seam of the back panel and the front casing to create an initial opening.
    • Insert the metal spudger within the opening.
    • Move the metal spudger down the seam, prying the back panel open as you go.
    • Once a large enough opening is made, pry the entire back panel off with your hand.
    • You will hear loud popping from the magnetized latches. This is not causing damage to the device and will require some force to open.
  6. Samsung Galaxy View Battery Replacement: 6 단계, 이미지 1/2 Samsung Galaxy View Battery Replacement: 6 단계, 이미지 2/2
    • Using the plastic opening tool, lift off the orange press-fit connector (marked with a white arrow-head) where it attaches to the motherboard.
  7. Samsung Galaxy View Battery Replacement: 7 단계, 이미지 1/3 Samsung Galaxy View Battery Replacement: 7 단계, 이미지 2/3 Samsung Galaxy View Battery Replacement: 7 단계, 이미지 3/3
    • Remove the 6 screws (4 mm in length) using the Phillips #0 screwdriver.
    • Remove the battery from the device.
결론
다른 40명이 해당 안내서를 완성하였습니다.
Roger Pena
회원 가입일: 10/06/16
1,141 평판
안내서 1개 작성함
Cal Poly, Team 4-5, Livingston Fall 2016 Cal Poly, Team 4-5, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S4G5
4 회원들
안내서 12개 작성하였습니다
댓글 29개
I’m not sure if it’s the battery or the cord
Swheet - 답글
What size is the battery that fits into the SAMSUNG TAB VIEW?
Ricky Lee Lidel - 답글
Thank You, Sooo much. This guide is a true money and time saver. Worked like a gem .
Mike Rowe - 답글
I can't find Lithium ION 11.3 V 5700mAh battery for my Samsung Galaxy 18.4View Tablet, does anyone know where to get one?
What's difference between a 5700mAh battery and 5900mAh battery
Sue ELLEN R FONTENOT - 답글
Where can I find battery replacement for galaxy view
Greg Dover -
댓글 쓰기
조회 통계:
24 시간 전: 11
7일 전: 46
30일 전: 167
전체 시간: 25,384
