주요 콘텐츠로 건너뛰기
Samsung Galaxy View Speakers Replacement
필요한 것
  1. Samsung Galaxy View Speakers Replacement, Kickstand: 1 단계, 이미지 1/1
    • Place the device on a hard flat surface with its screen facing downwards.
    • Rotate the the kickstand so that the handle grip hole is up in the air and not touching the back of the tablet.
  2. Samsung Galaxy View Speakers Replacement: 2 단계, 이미지 1/3 Samsung Galaxy View Speakers Replacement: 2 단계, 이미지 2/3 Samsung Galaxy View Speakers Replacement: 2 단계, 이미지 3/3
    • Stick the pointy end of the spudger into the circular opening of the leftmost metallic latch.
    • With the spudger still inserted, pry the spudger to the right pushing the latch opening along with it.
    • Once the latch is moved to the right, pull up on the left side of the kickstand, releasing it from the back of the tablet.
    • Repeat the previous steps for the rightmost latch, and then lift the kickstand off the back of the tablet.
  3. Samsung Galaxy View Speakers Replacement, Battery: 3 단계, 이미지 1/2 Samsung Galaxy View Speakers Replacement, Battery: 3 단계, 이미지 2/2
    • Check the device is completely turned off.
    • Slide open the SD compartment tab, and remove the SD card to ensure all data is saved.
  4. Samsung Galaxy View Speakers Replacement: 4 단계, 이미지 1/3 Samsung Galaxy View Speakers Replacement: 4 단계, 이미지 2/3 Samsung Galaxy View Speakers Replacement: 4 단계, 이미지 3/3
    • Remove the 4 screws (4 mm in length) using the Phillips #0 screwdriver.
  5. Samsung Galaxy View Speakers Replacement: 5 단계, 이미지 1/3 Samsung Galaxy View Speakers Replacement: 5 단계, 이미지 2/3 Samsung Galaxy View Speakers Replacement: 5 단계, 이미지 3/3
    • Insert the plastic opening tool between the seam of the back panel and the front casing to create an initial opening.
    • Insert the metal spudger within the opening.
    • Move the metal spudger down the seam, prying the back panel open as you go.
    • Once a large enough opening is made, pry the entire back panel off with your hand.
    • You will hear loud popping from the magnetized latches. This is not causing damage to the device and will require some force to open.
  6. Samsung Galaxy View Speakers Replacement: 6 단계, 이미지 1/2 Samsung Galaxy View Speakers Replacement: 6 단계, 이미지 2/2
    • Using the plastic opening tool, lift off the orange press-fit connector (marked with a white arrow-head) where it attaches to the motherboard.
  7. Samsung Galaxy View Speakers Replacement: 7 단계, 이미지 1/3 Samsung Galaxy View Speakers Replacement: 7 단계, 이미지 2/3 Samsung Galaxy View Speakers Replacement: 7 단계, 이미지 3/3
    • Remove the 6 screws (4 mm in length) using the Phillips #0 screwdriver.
    • Remove the battery from the device.
  8. Samsung Galaxy View Speakers Replacement, Speakers: 8 단계, 이미지 1/3 Samsung Galaxy View Speakers Replacement, Speakers: 8 단계, 이미지 2/3 Samsung Galaxy View Speakers Replacement, Speakers: 8 단계, 이미지 3/3
    • Use the plastic opening tool to disconnect the white bundled cable connector that links the left speaker to the motherboard via a red wire.
    • Remove the left speaker by gripping it with your hand and lifting it off of the pegs.
  9. Samsung Galaxy View Speakers Replacement: 9 단계, 이미지 1/2 Samsung Galaxy View Speakers Replacement: 9 단계, 이미지 2/2
    • Remove the right speaker by gripping it with your hand and pulling it straight up and off of the pegs.
    • The white bundled wire connector, and the red wire attaching the speaker to the motherboard, will come off when lifting the speaker.
결론
Miguel Becerra
회원 가입일: 10/06/16
251 평판
안내서 1개 작성함
Cal Poly, Team 4-5, Livingston Fall 2016 Cal Poly, Team 4-5, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S4G5
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 16
전체 시간: 2,108
