주요 콘텐츠로 건너뛰기
Samsung Galaxy View Speakers Replacement
필요한 것
  1. Samsung Galaxy View Speakers Replacement, Kickstand: 1 단계, 이미지 1개 중 1개
    • Place the device on a hard flat surface with its screen facing downwards.
    • Rotate the the kickstand so that the handle grip hole is up in the air and not touching the back of the tablet.
  2. Samsung Galaxy View Speakers Replacement: 2 단계, 이미지 3개 중 1개 Samsung Galaxy View Speakers Replacement: 2 단계, 이미지 3개 중 2개 Samsung Galaxy View Speakers Replacement: 2 단계, 이미지 3개 중 3개
    • Stick the pointy end of the spudger into the circular opening of the leftmost metallic latch.
    • With the spudger still inserted, pry the spudger to the right pushing the latch opening along with it.
    • Once the latch is moved to the right, pull up on the left side of the kickstand, releasing it from the back of the tablet.
    • Repeat the previous steps for the rightmost latch, and then lift the kickstand off the back of the tablet.
  3. Samsung Galaxy View Speakers Replacement, Battery: 3 단계, 이미지 2개 중 1개 Samsung Galaxy View Speakers Replacement, Battery: 3 단계, 이미지 2개 중 2개
    • Check the device is completely turned off.
    • Slide open the SD compartment tab, and remove the SD card to ensure all data is saved.
  4. Samsung Galaxy View Speakers Replacement: 4 단계, 이미지 3개 중 1개 Samsung Galaxy View Speakers Replacement: 4 단계, 이미지 3개 중 2개 Samsung Galaxy View Speakers Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the 4 screws (4 mm in length) using the Phillips #0 screwdriver.
  5. Samsung Galaxy View Speakers Replacement: 5 단계, 이미지 3개 중 1개 Samsung Galaxy View Speakers Replacement: 5 단계, 이미지 3개 중 2개 Samsung Galaxy View Speakers Replacement: 5 단계, 이미지 3개 중 3개
    • Insert the plastic opening tool between the seam of the back panel and the front casing to create an initial opening.
    • Insert the metal spudger within the opening.
    • Move the metal spudger down the seam, prying the back panel open as you go.
    • Once a large enough opening is made, pry the entire back panel off with your hand.
    • You will hear loud popping from the magnetized latches. This is not causing damage to the device and will require some force to open.
  6. Samsung Galaxy View Speakers Replacement: 6 단계, 이미지 2개 중 1개 Samsung Galaxy View Speakers Replacement: 6 단계, 이미지 2개 중 2개
    • Using the plastic opening tool, lift off the orange press-fit connector (marked with a white arrow-head) where it attaches to the motherboard.
  7. Samsung Galaxy View Speakers Replacement: 7 단계, 이미지 3개 중 1개 Samsung Galaxy View Speakers Replacement: 7 단계, 이미지 3개 중 2개 Samsung Galaxy View Speakers Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the 6 screws (4 mm in length) using the Phillips #0 screwdriver.
    • Remove the battery from the device.
  8. Samsung Galaxy View Speakers Replacement, Speakers: 8 단계, 이미지 3개 중 1개 Samsung Galaxy View Speakers Replacement, Speakers: 8 단계, 이미지 3개 중 2개 Samsung Galaxy View Speakers Replacement, Speakers: 8 단계, 이미지 3개 중 3개
    • Use the plastic opening tool to disconnect the white bundled cable connector that links the left speaker to the motherboard via a red wire.
    • Remove the left speaker by gripping it with your hand and lifting it off of the pegs.
  9. Samsung Galaxy View Speakers Replacement: 9 단계, 이미지 2개 중 1개 Samsung Galaxy View Speakers Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the right speaker by gripping it with your hand and pulling it straight up and off of the pegs.
    • The white bundled wire connector, and the red wire attaching the speaker to the motherboard, will come off when lifting the speaker.
결론
작성자
3다른 기여자 명과 함께
Miguel Becerra
회원 가입일: 10/06/16
251 평판
안내서 1개를 작성함
Cal Poly, Team 4-5, Livingston Fall 2016 Cal Poly, Team 4-5, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S4G5
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 12
전체 시간: 2,159
