주요 콘텐츠로 건너뛰기
Samsung Galaxy Watch Active2 Back Cover Replacement
필요한 것
  1. Samsung Galaxy Watch Active2 Back Cover Replacement, Turn off the watch: 1 단계, 이미지 2개 중 1개 Samsung Galaxy Watch Active2 Back Cover Replacement, Turn off the watch: 1 단계, 이미지 2개 중 2개
    • Turn off the Galaxy Watch Active2 by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
    • When the "Power off" symbol appears, tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
  2. Samsung Galaxy Watch Active2 Back Cover Replacement, Remove the rear screws: 2 단계, 이미지 1개 중 1개
    • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
  3. Samsung Galaxy Watch Active2 Back Cover Replacement, Separate the back cover from the housing: 3 단계, 이미지 3개 중 1개 Samsung Galaxy Watch Active2 Back Cover Replacement, Separate the back cover from the housing: 3 단계, 이미지 3개 중 2개 Samsung Galaxy Watch Active2 Back Cover Replacement, Separate the back cover from the housing: 3 단계, 이미지 3개 중 3개
    • Use an opening pick and place it between the plastic back cover and the metal housing near the buttons.
    • Push the opening pick into the gap to separate the back cover from the housing.
    • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
  4. Samsung Galaxy Watch Active2 Back Cover Replacement, Disconnect the sensor array: 4 단계, 이미지 2개 중 1개 Samsung Galaxy Watch Active2 Back Cover Replacement, Disconnect the sensor array: 4 단계, 이미지 2개 중 2개
    • Carefully lift the back cover to access the sensor array connector.
    • Use a spudger to disconnect the sensor array from the motherboard.
  5. Samsung Galaxy Watch Active2 Back Cover Replacement, Remove the back cover: 5 단계, 이미지 1개 중 1개
    • Remove the back cover.
결론
다른 14명이 해당 안내서를 완성하였습니다.
Tobias Isakeit
회원 가입일: 03/31/14
129,223 평판
안내서 189개를 작성함
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 회원
Business
1 회원
안내서 1,145개를 작성함
6가이드 댓글
What kind of glue would you use if the plastic of the back cover fell off?
Dave Hains - 답글
This happened to me as well. I opted to replace the entire adhesive-attached back cover. You can find kits that include a new back with a new adhesive gasket already attached. You just need to take off the old one and make sure it's clean before putting on the new one. I bought this one on ebay: https://www.ebay.com/itm/164638316825
John S. -
Hello. Where can i get the back cover with adhesive as a replacement or just the adhesvie? I noticed it is a weird rubbery glue and i cannot source this anywhere.
Arbuzov Paul - 답글
Ilona Smit - 답글
Why would you use glue? The back is fixed with screws.
If there is a loose part on the back cover you might want to try a glue like the E6000, B7000 or T9000 (there are different combinations out there)
Tobias Isakeit -
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 51
지난 30일: 260
전체 시간: 43,042
