주요 콘텐츠로 건너뛰기
Samsung Galaxy Watch Motherboard Replacement
필요한 것
  1. Samsung Galaxy Watch Motherboard Replacement, Opening Procedure: 1 단계, 이미지 1/1
    • Remove the four Tri-point #00 screws (4.2 mm length) on the backside of the watch.
  2. Samsung Galaxy Watch Motherboard Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Watch Motherboard Replacement: 2 단계, 이미지 2/2
    • Use an opening tool to get between the back cover and the metal housing of the watch.
    • Carefully pry the plastic back cover open.
    • Don't remove the back cover yet. There is a flex cable running to the core assembly inside.
  3. Samsung Galaxy Watch Motherboard Replacement: 3 단계, 이미지 1/2 Samsung Galaxy Watch Motherboard Replacement: 3 단계, 이미지 2/2
    • Lay down the watch and lift the back cover to access the sensor connector on the motherboard.
  4. Samsung Galaxy Watch Motherboard Replacement: 4 단계, 이미지 1/2 Samsung Galaxy Watch Motherboard Replacement: 4 단계, 이미지 2/2
    • Use a spudger to disconnect the sensor flex cable from the motherboard.
  5. Samsung Galaxy Watch Motherboard Replacement: 5 단계, 이미지 1/3 Samsung Galaxy Watch Motherboard Replacement: 5 단계, 이미지 2/3 Samsung Galaxy Watch Motherboard Replacement: 5 단계, 이미지 3/3
    • Remove the back cover.
    • When closing the watch make sure the rubber gasket is undamaged or replace it with a new one.
  6. Samsung Galaxy Watch Motherboard Replacement, Core Assembly Removal: 6 단계, 이미지 1/2 Samsung Galaxy Watch Motherboard Replacement, Core Assembly Removal: 6 단계, 이미지 2/2
    • Use a spudger to disconnect the display flex cable from the motherboard.
  7. Samsung Galaxy Watch Motherboard Replacement: 7 단계, 이미지 1/2 Samsung Galaxy Watch Motherboard Replacement: 7 단계, 이미지 2/2
    • Lift the core unit out of the housing.
    • The core's plastic frame sits tight inside the housing.
    • Carefully thread the display flex cable through the gap of the core's plastic frame.
  8. Samsung Galaxy Watch Motherboard Replacement, Motherboard: 8 단계, 이미지 1/2 Samsung Galaxy Watch Motherboard Replacement, Motherboard: 8 단계, 이미지 2/2
    • Use a spudger to disconnect the hall sensor flex cable.
  9. Samsung Galaxy Watch Motherboard Replacement: 9 단계, 이미지 1/3 Samsung Galaxy Watch Motherboard Replacement: 9 단계, 이미지 2/3 Samsung Galaxy Watch Motherboard Replacement: 9 단계, 이미지 3/3
    • Use a pair of tweezers to gently peel both button cables from the plastic frame.
    • The button cables have metal plates behind them. These plates should remain on the cables.
  10. Samsung Galaxy Watch Motherboard Replacement: 10 단계, 이미지 1/1
    • Remove the single Phillips #00 screw (3.4 mm length).
  11. Samsung Galaxy Watch Motherboard Replacement: 11 단계, 이미지 1/3 Samsung Galaxy Watch Motherboard Replacement: 11 단계, 이미지 2/3 Samsung Galaxy Watch Motherboard Replacement: 11 단계, 이미지 3/3
    • Insert a spudger into the small gap underneath the motherboard where the cutout in the plastic frame is.
    • Lift the motherboard by twisting the spudger.
    • Slide the motherboard out from under the plastic tab.
  12. Samsung Galaxy Watch Motherboard Replacement: 12 단계, 이미지 1/1
    • Remove the motherboard.
결론
If possible, turn on your device and test your repair before resealing.
다른 7명이 해당 안내서를 완성하였습니다.
Tobias Isakeit
회원 가입일: 03/31/14
117,293 평판
안내서 188개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,521개 작성하였습니다
댓글 7개
Anyone know where to purchase a Galaxy Watch mother board?
lorne serpa - 답글
What is the part number, or where can you get the motherboard?
Nick Henthorn - 답글
Where can the motherboard be purchased from for Galaxy Watch ?
Mohammed Aamir - 답글
I got a motherboard on ebay. Including import duties it was something like 90$. Shipped to Denmark.
Definitely cheaper than repair shop and absolutely more fun! :)
Agris Jurjans - 답글
Hello,
Do you know if switching a motherboard from a GW46 Bluetooth only (R800) to a GW46 LTE (R805) is a straight swap or additional parts are needed?
As my R800 sensors are dead and i need to replace the motherboard and the back cover anyway.
Thanks
BRazvy - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 19
30일 전: 132
전체 시간: 11,769
