소개
Use this guide to replace the motherboard in a Samsung Galaxy Watch3.
필요한 것
Before starting repairs, take your watch off the charger and power it down.
Use a Tri-point Y00 driver to unfasten the four screws on the back of the watch.
Insert an opening tool between the back cover and the metal housing.
Twist the opening tool to create a wider gap.
Lay the watch face down.
Carefully lift the back cover up from the edge with the buttons to access the sensor connector.
Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
Use the flat end of a spudger to disconnect the flex cables of the side buttons, the display and the hall sensor.
The motherboard is held in place by two small plastic clips.
Use a pair of blunt tweezers to lift the motherboard out from underneath the plastic clips towards the buttons.
Remove the motherboard.
If possible, turn on your device and test your repair before resealing.
다른 2명이 해당 안내서를 완성하였습니다.
