주요 콘텐츠로 건너뛰기
Samsung Galaxy Xcover GT-S5690 LCD Replacement
필요한 것
  1. Samsung Galaxy Xcover GT-S5690 LCD Replacement, LCD: 1 단계, 이미지 1/1
    • Here is the Samsung Galaxy Xcover, with the LCD broken, that will be replaced.
  2. Samsung Galaxy Xcover GT-S5690 LCD Replacement: 2 단계, 이미지 1/1
    • The first step, is remove the battery door. It comes with a security lock, that has to be on open position. Start opening from bottom, and releasing from the side edges.
  3. Samsung Galaxy Xcover GT-S5690 LCD Replacement: 3 단계, 이미지 1/2 Samsung Galaxy Xcover GT-S5690 LCD Replacement: 3 단계, 이미지 2/2
    • Remove with a flat screwdriver, the volume button and the power button
    • Now, with a Phillpis Screwdriver, remove all the screws from the backcover.
  4. Samsung Galaxy Xcover GT-S5690 LCD Replacement: 4 단계, 이미지 1/2 Samsung Galaxy Xcover GT-S5690 LCD Replacement: 4 단계, 이미지 2/2
    • With a flat screwdriver or plastic opener, separate the front case from the rear case. It will be easy!
    was not easy at all. many thanks. PC World
    Jack Chauhan - 답글
  5. Samsung Galaxy Xcover GT-S5690 LCD Replacement: 5 단계, 이미지 1/3 Samsung Galaxy Xcover GT-S5690 LCD Replacement: 5 단계, 이미지 2/3 Samsung Galaxy Xcover GT-S5690 LCD Replacement: 5 단계, 이미지 3/3
    • Remove the screw on the lower zone of the main board. The screw is the same of the case, so dont worry if you mix them.
    • Now, with a pliers, unplug the camera and the front speaker. Now, we are going to lift the main board, but ...
    • be careful, below is the LCD flex cable!
  6. Samsung Galaxy Xcover GT-S5690 LCD Replacement: 6 단계, 이미지 1/2 Samsung Galaxy Xcover GT-S5690 LCD Replacement: 6 단계, 이미지 2/2
    • Remove the LCD flat cable, and then, remove the 2 screws on the sides of the front cover. They are the same as the others screws...
    • Now, you can take apart the chassis from the front cover, leaving only the display and the touch.
  7. Samsung Galaxy Xcover GT-S5690 LCD Replacement: 7 단계, 이미지 1/2 Samsung Galaxy Xcover GT-S5690 LCD Replacement: 7 단계, 이미지 2/2
    • Lift up the black retainer, and take off the touch flex cable.
    • Be careful, the flex has double side tape below the IC.
    • Now, with a knife or cutter, lift carefully the LCD unit. Place the new LCD, and reassembly the phone.
    • In the near future, I´ll post how to replace the touch screen!
결론
다른 3명이 해당 안내서를 완성하였습니다.
Jaime
회원 가입일: 11/05/13
3,333 평판
안내서 4개 작성하였습니다
댓글 한 개
Good and clear. Pics are much better than movie, thank you very much!
pierrequivoyage - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 20
전체 시간: 6,759
