이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use the blue plastic opening tool to pry the back-panel off of the device.
Use a Phillips #000 screwdriver to remove the four 5mm screws located in the corner of the interior back panel.
Remove the SD card as well by sliding the card out of its slot.
Use the metal pry tool to separate the interior back panel from the interior hardware and screen.
Disconnect the orange motherboard connection, then remove the interior hardware from the front screen display.
Use a Phillips #000 screwdriver to remove the five 2mm screws located in the corner of the silver protective panel.
If the motherboard is cracked or damaged, then replace with a new one.
